Help with timing belt and cam gears.
Old Jul 18, 2003 | 06:58 AM
Poop111444's Avatar
Default Help with timing belt and cam gears.
Ok, I am in the process of reinstalling my t belt after i took off my head. I understand the jist of this process, but when adjusting my cams to get them to line up without the belt on, the exhaust cam spins freely with a 14mm wrench, but the intake cam is a bitch to move, and it wont spin both ways. Only if i go clockwise with the bolt, its already on as tight as it will go so it spins the gear.
Is there something wrong? BTW none of the pistons are at TDC
Old Jul 18, 2003 | 09:02 AM
DEVIN22CBR's Avatar
Default Re: Help with timing belt and cam gears. (si_mekanik)
I don't understand fully, but you were suppose to set everything at TDC before you took the crank pulley off because the cams aren't going to move freely . Hope that helps I illiterate
Old Jul 18, 2003 | 09:32 AM
Poop111444's Avatar
Default Re: Help with timing belt and cam gears. (BALL BAG)
Actually, I figured it out. I took off the distributor in and it was in a bit crooked I guess, but the teeth did go in the cam. Weird. Now it spins freely. Everything is lined up, but I know the belt is not supposed to be on super tight, but it is one decently snug, with some looseness I guess. I took a video, is this good?
Right click save target as
http://home.comcast.net/~kevinsurvey/P7190067.MOV
Old Jul 18, 2003 | 11:48 AM
DEVIN22CBR's Avatar
Looks perfect ..I remember when I just did mine it was to tight and whinned like a son of a bitch. Then i forgot to set it to TDC when i tried to re tension it and all hell broke loose and the tensionor spring slipped and I had to redo it all over agian!! Horrible day
Old Aug 2, 2003 | 11:45 PM
Muckman's Avatar
Moderator in Chief
Default Re: Help with timing belt and cam gears. (EVIL BALL BAG)
What are you guys using for 5mm pins to secure the camshafts from turning when installing a new Timming Belt? I've been using 5mm allen wrenches but there is still too much play on the cams.
92EG8
Nov 2, 2008 03:41 AM
drumminforev
Oct 17, 2006 11:57 AM
redlseg
Apr 20, 2005 07:07 PM
