Oil in exhaust port?
Old Jul 16, 2003 | 07:22 PM
b20ek's Avatar
Default Oil in exhaust port?
What could cause oil leakage in the exhaust port but valves are not bent? Could that be a bad valve guid seal?
Old Jul 17, 2003 | 01:13 PM
b20ek's Avatar
Default Re: Oil in exhaust port? (b20ek)
hello?
Old Jul 17, 2003 | 01:16 PM
kyle h.'s Avatar
you guessed it.
Old Jul 17, 2003 | 01:17 PM
coos's Avatar
Even though the valves are not bent, the valve guides could be leaking.
Old Jul 17, 2003 | 04:32 PM
Rocket's Avatar
Default Re: Oil in exhaust port? (coos)
Could be poor oil ring control. (oil can get sucked up past the pistons rings on the intake stroke)
Old Jul 17, 2003 | 07:19 PM
b20ek's Avatar
Default Re: Oil in exhaust port? (Rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">Could be poor oil ring control. (oil can get sucked up past the pistons rings on the intake stroke)</TD></TR></TABLE>
This is what my machinist told me. The block is brand new and hasn't even been broken in yet. It has 0 miles since rebuild. I have only been able to get it to idle and not very well. The plugs were extremely fouled and #3 was wet with what I thought was gas untill I took the head off and realized it was oil. I think it's just do to the fact that the engine is not broken in yet and the clearance with je pistons is supposed to be twice as big as recomended due to the expansion rate of the piston. I just hope that I put the rings the right side up. I am 99.5% sure on this.
Old Jul 18, 2003 | 06:37 AM
Rocket's Avatar
You need to get on the motor then to break in the rings.
Old Jul 22, 2003 | 08:14 AM
coos's Avatar
no, don't get on a motor to break it in. Take it for a nice long freeway drive.
Mishako129
Feb 6, 2014 06:55 PM
Mik2006
Feb 2, 2010 03:50 PM
Hharrishonda
Jun 14, 2008 05:59 AM
SD99GSR
Jul 24, 2007 03:36 PM
quik1
May 17, 2004 07:15 PM
