Which bearings to use in a 1st gen B16?
Old Jul 16, 2003 | 01:58 PM
spacetuna's Avatar
Default Which bearings to use in a 1st gen B16?
Which bearings do I use on a jap spec 1st generation B16???
Old Jul 16, 2003 | 08:01 PM
Esoterikos's Avatar
Default Re: Which bearings to use in a 1st gen B16? (spacetuna)
which bearings are you replacing? rod? crank? wheel? camshaft?
Old Jul 17, 2003 | 04:35 AM
spacetuna's Avatar
Default Re: Which bearings to use in a 1st gen B16? (S8P-tuner)
All the bearings for the bottom end.
Old Jul 17, 2003 | 07:36 AM
Esoterikos's Avatar
you could go to your local honda dealer and order the rebuild kit, or go to a parts store and do the same...
most kits that are available are either manufactured in japan (good) or made by federal mogul (also good). i think the biggest thing here with durability is not the brand of parts used, but the time and care taken when installing these parts. are you rebuilding this engine yourself? is it your first time? if so, have someone show you how to properly use tools such as feeler gauges, plastigage, telescopic bore gauges, etc...
Old Jul 17, 2003 | 08:48 AM
BeerMan's Avatar
use the search function and put in "ACL". These are the bearings I am using in my B16a1 rebuild. They are cheaper and supposedly better than Honda bearings. If you have any doubts IM Rocket or Earl. They both sell ACL bearings and will likely answer any questions you have, AFTER YOU SEARCH.
Old Jul 17, 2003 | 09:08 AM
spacetuna's Avatar
Default Re: Which bearings to use in a 1st gen B16? (BeerMan)
I want the stock bearings and I need the color code if anyone can help out I'd appreciate it.
Old Jul 17, 2003 | 09:19 AM
BeerMan's Avatar
you have to match the letters on your block with the numbers on the crank. With that combination you can figure out what color code you need. I don't have my Helms with me to look at the chart, but you could probably find one if you searched.
ek_civic96
Oct 24, 2008 05:40 AM
golangti
Dec 20, 2007 10:02 AM
Importracer_001
Oct 31, 2004 11:35 AM
aeolus
May 1, 2003 06:47 AM
