clicking when i release clutch?
Old Jul 16, 2003 | 03:16 PM
Mar_DC2's Avatar
Default clicking when i release clutch?
i already searched this and i didnt find the answer i was looking for. lately my car has been making clicking sounds when i release the clutch. it only used to happen when i would start in 1st gear, but it has since happened when shifting into 2nd and 3rd, and sometimes when i let off the throttle while in gear. it sounds like its coming from both front wheels. it only happens when it's in gear, when it's in neutral it's just fine so i dont think its anything with the pedal. i was thinking the CV joints might be a little worn, this is on a 99 Si with 90k miles. anyone have some input?? in advance
BTW this is all during normal driving.
Old Jul 16, 2003 | 06:09 PM
Mar_DC2's Avatar
Default Re: clicking when i release clutch? (Btown_99Si)
bump
Old Jul 16, 2003 | 08:50 PM
Mar_DC2's Avatar
up.
Old Jul 16, 2003 | 11:01 PM
holisticbeatz's Avatar
Sounds like maybe it's a worn out throwout bearing.
Old Jul 16, 2003 | 11:30 PM
Mar_DC2's Avatar
Default Re: clicking when i release clutch? (holisticbeatz)
yeah that is a possibility. if it was the throwout bearing, would it sound like it was coming from the front wheels? i havent heard it from outside the car though, so it may sound different.
for the response.
Old Jul 17, 2003 | 04:19 AM
1bad-eg's Avatar
I know that a very light clicking is the differential which is normal. Could that be the noise you are hearing?
Old Jul 17, 2003 | 01:03 PM
Mar_DC2's Avatar
Default Re: clicking when i release clutch? (1bad-eg)
might be, but its most likely not since it just started happening about 3-4 weeks ago. thanks
Old Jul 17, 2003 | 03:08 PM
Pengo's Avatar
can't be throwout bearing. u said urself it only makes sound while in gear. if sound goes away when u clutch in then it can be throwout b/c that's when its being pushed out against pp. if it's only making the sound while in gear and the sound goes away when u push down on the clutch pedal, i would say it may be the clutch mainshaft bearing. can u describe the sound more accurately?
Old Jul 17, 2003 | 03:41 PM
poison's Avatar
Hmm, how loud is the clicking noise? And this only happens while in gear?
Is it allllll the time while in gear while going, or at a dead stop?
Old Jul 17, 2003 | 05:17 PM
Mar_DC2's Avatar
Default Re: clicking when i release clutch? (Pengo)
it sounds like a kind of creaking, i would say kind of like twigs being broken. i just check the axles today and they are perfectly fine, cv boots are good, tie rods are fine, there's nothing wrong with the suspention.
brandon, it only happens when when i release the clutch pedal while going into gear and there is the initial stress on the clutch, like starting from a stop and after shifing into 2nd, etc...
Old Jul 17, 2003 | 06:14 PM
poison's Avatar
Sounds definitely like its something in the clutch housing like the TOB or pressure plate.
I'd have to look at it. Is it loud?
Old Jul 17, 2003 | 06:23 PM
Mar_DC2's Avatar
Default Re: clicking when i release clutch? (poison)
yeah, its pretty noticeable, especially starting from a stop. if it is something with the clutch or TOB then its no big deal, i'll be replacing it within the next 6 months.
Old Jul 17, 2003 | 07:00 PM
LittleBlueSi's Avatar
my car makes a similiar nose but only when i push the clutch down in first gear... i have a clutch with only 15,000 miles on it? what could this be?
Old Jul 17, 2003 | 09:11 PM
Mar_DC2's Avatar
Default Re: clicking when i release clutch? (LittleBlueSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LittleBlueSi &raquo;</TD></TR><TR><TD CLASS="quote">my car makes a similiar nose but only when i push the clutch down in first gear... i have a clutch with only 15,000 miles on it? what could this be?</TD></TR></TABLE>
my old car did the same thing for a while after i had the clutch replaced by honda. it went away after about 5 months
Old Jul 18, 2003 | 01:47 PM
1bad-eg's Avatar
If it's a creaking type of noise it's more than likely something in the tranny housing. ( clutch, etc.)
xluigix47
Sep 28, 2014 02:21 PM
Koko4
17
Jul 17, 2013 07:03 PM
renzis00
Oct 12, 2012 08:06 PM
nnamssorxela
Transmission & Drivetrain
30
Jun 29, 2011 11:09 PM
sfgiants11
15
May 26, 2005 02:14 PM
