Redline for fully build B20-Vtec Turbo engine????
Old Nov 4, 2004 | 10:45 AM
hovic's Avatar
Default Redline for fully build B20-Vtec Turbo engine????
Hi..
I´m building a fully build B20 Vtec turbo engine and I was wondering how high can I rev this engine.. Here are the parts:
dart engine block 84mm bore
manley turbo rods
JE 9:1 pistons
cometic head gasket
eagle crank
full ferrea valve train (combo kit)
GSR cams
ITR oil pump
full balanced
Thanx for your help
Old Nov 4, 2004 | 10:04 PM
hovic's Avatar
Default Re: Redline for fully build B20-Vtec Turbo engine???? (hovic)
ttt
Old Nov 5, 2004 | 03:00 AM
non-VTEC's Avatar
with stock GSR cams i would say about 8100rpm
you can rev it much higher but your peak power will probably be under 8100rpm......
Old Nov 5, 2004 | 08:20 AM
hovic's Avatar
Default Re: Redline for fully build B20-Vtec Turbo engine???? (non-VTEC)
Thanx for reply.. some more ideas maybe from the FI guys are using stock GSR cams in their turbo setups.
Old Nov 5, 2004 | 08:30 AM
mmuller's Avatar
Mad Scientist
i would not rev any higher than stock with your cams
Old Nov 5, 2004 | 12:40 PM
Sack Master's Avatar
Default Re: Redline for fully build B20-Vtec Turbo engine???? (mmuller)
Being turbo its probably making power higher than 8k. That block can probably handle over 9k. But only rev it as high as you make power. I would say 8500 is probably about the limit.
Old Nov 6, 2004 | 01:07 AM
hovic's Avatar
Default Re: Redline for fully build B20-Vtec Turbo engine???? (Sack Master)
I thought stock GSR cams will make power up to 10500 rpm
What kind of turbo cam is made for higher reving?? Crower??? Crane cams??
I was planing to rev between 9000 to 9500 rpm with making power of course ;-) and I thought the GSR cams would be fine :-(
Old Nov 6, 2004 | 01:38 PM
hovic's Avatar
bump
Old Nov 6, 2004 | 03:46 PM
dumpeDc2's Avatar
I'm a Jackass
till it stops making power
Link16
Apr 18, 2008 05:20 AM
murtnabila
Jul 26, 2005 08:53 PM
91DroppedHatch
Jun 21, 2005 11:53 AM
dominate9
Feb 3, 2004 12:56 PM
igotyofire
Sep 10, 2003 04:31 PM
