Need help about Bseries halfshafts.
I heard that I can't use a 94-01 Integ halfshaft on a 92-95 civic with a Bseries swap, but I did hear 90-93 Integ, DOHC-Delsol, and 99-00 Civic SI halfshafts work, please give me a list of all the halfshafts that work.
Which ever Intermediate shaft you use you will have to use the corresponding axles. If you use the 94-95 I shaft then use 94-95 axles. If you use the 90-93 use the 90-93 axles. The 90-93 I-shaft is most commonly used in the EF's but, Either will work.
Phil
Phil
