Piston Design....
Old Nov 6, 2004 | 08:39 PM
Cidone's Avatar
Default Piston Design....
Hey im getting ready to order super big bore pistons for my GSR project... Im going to be running 86mm 12.1 CR pistons... The Question i have is im getting them custom made and they want me to tell them what design i want??? Now i know that CTR style pistons are super i compression but what about ITR style?? Im just so confused... If anyone can help that would be awesome.....
The prelude pistons has same design as the ITRs piston....
Old Nov 6, 2004 | 10:26 PM
PrettyLude's Avatar
customs will be expensive, why do you want to go with a bore that big?
Old Nov 7, 2004 | 07:42 AM
mmuller's Avatar
Mad Scientist
Default Re: Piston Design.... (Cidone)
the higher the dome the worst the combustion process is
Old Nov 7, 2004 | 09:13 AM
93BoostedCivic's Avatar
PRELUDE TYPE-S PISTONS ARE FLOATING PISTON?
I DIDNT KNOW THAT
GET SOME TODA RACING PISTONS 12.5:1
Old Nov 7, 2004 | 09:30 AM
ZoRG's Avatar
Default Re: (93BoostedCivic)
Make sure you research problems with roundness, when you have the sleeves so thin they don't stay round, and you suffer from excessive blow by.
I don't know what the limit is on B-Series motors though.
Old Nov 7, 2004 | 09:48 AM
Rob Dizzle's Avatar
im pretty sure you can get some ib spec wisecos that are not super hard to get
look at the bottom of the page
http://importbuilders.com/pistons.html
you really need to post up more info about your setup. its not even that clear what your question is.
and the lame tard who said get toda, they most likely dont make a 86mm for b series
Old Nov 7, 2004 | 10:44 AM
Cidone's Avatar
Default Re: Piston Design.... (Bob-DC2)
Okay im building a GSR bottom end right now... I have Darton sleeves and Eagle rods.... I havnt gotten pistons yet because DH-Racing.com said i would need to know what kinda design i want for the pistons... Now i really dont care what they look like as long as i got 12:1.1 CR... Thats all i care about so why should i have to tell them what i want them to look like?
Old Nov 7, 2004 | 12:08 PM
atcrx's Avatar
The combustion chamber design dictates what piston design you have. If you are using a head with a unmodified combustion chamber then you could use a stock style piston. If someone has welded up your head & clover leafed it then you will need a different piston design.
Old Nov 7, 2004 | 05:39 PM
Cidone's Avatar
Default Re: Piston Design.... (atcrx)
When i do the bore im going to have to get my combusion chamber bored as well right? What cover leafed mean???
Old Nov 7, 2004 | 09:04 PM
Rob Dizzle's Avatar
dude you are really too deep into this. first mistate is going with dh-racing.
cancel your order with them and find someone else to go with.
im not sure why you are going with them but i would strongly recomend going with someoen else. there are better companies out there that can build you an engine.
Old Nov 8, 2004 | 07:40 AM
Cidone's Avatar
Thats cool... Im just new to hondas im coming over from like 7 years deep in VWs so thanks alot for helping me to this point... Could you recommend some companys for me?
Old Nov 8, 2004 | 10:57 AM
Rob Dizzle's Avatar
well it depends upon your area.
portflow.com for headwork. reliable, fair pricing and proven performance.
call earl or bensons for engine work. or call will @ exospeed.com for work as well on your engine.
its just that dh racing in my opinion isnt nearly all that great and there work isnt worth the price.
Old Nov 9, 2004 | 03:09 PM
civicsitek GanGsTa's Avatar
listen to Bob, DH is nothing but trouble.
Old Nov 10, 2004 | 12:41 PM
ExospeedAMcrx's Avatar
on a piston design, I'm assuming this is an all motor application.
You have to find out what the specs of your cam, lift/duration to design a piston to fit your setup.
but my concern is why such a big bore with a low 12:1 compression. the only time you should be going bigger than 84mm, is for MAX power and race applications. and at that point, compression should be in the 13:1+ range.
I guess what we really want to know first is:
What is your goals for the motor?
What is it going to be used for?
Old Nov 12, 2004 | 06:11 AM
Cidone's Avatar
Default Re: (exospeedAMcrx)
I want the most posible power i can get out of 93 octane.....
Old Nov 12, 2004 | 11:03 AM
Rob Dizzle's Avatar
Default Re: (Cidone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cidone &raquo;</TD></TR><TR><TD CLASS="quote">I want the most posible power i can get out of 93 octane.....</TD></TR></TABLE>
well who doesnt?
that isnt very helpful.
how much is your budget?
what cars do you want to beat?
what is your whp goal?
do you want to resleeve your block?
Old Nov 12, 2004 | 09:38 PM
Cidone's Avatar
Default Re: (Bob-DC2)
Im willing to spend whatever it takes. I just want to be in the 12s... Im going to fully rebuild my GSR.... thats what i want to do i would like to have around 230whp if its possible.....
Old Nov 13, 2004 | 03:40 AM
dflipmode's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cidone &raquo;</TD></TR><TR><TD CLASS="quote">Im willing to spend whatever it takes. I just want to be in the 12s... Im going to fully rebuild my GSR.... thats what i want to do i would like to have around 230whp if its possible.....</TD></TR></TABLE>
I recommend spending money on books and alot of reading first ....it just doesnt seem like you really know what you're getting yourself into...its nice and dandy to run in the 12s...everybody wants that....but 230whp on a gsr aint gonna run you in the 12s buddy....need to read and find out what combination works and yada yada yada....
Ryan#1
Oct 2, 2008 06:27 PM
hatchinprogress
Nov 14, 2005 08:36 PM
crx1856
Nov 3, 2003 12:00 AM
Halo
Dec 19, 2002 07:40 AM
