What lines need to be tee'd off? AEBS typhoon install.
Old Nov 4, 2004 | 06:12 PM
Two_K Si's Avatar
Default What lines need to be tee'd off? AEBS typhoon install.
I did not get any responses in the all motor forum. I remember reading that some lines need to be tee'd for the install of a typhoon. IIRC, it was the emissions canister, but what do you tee that into. Also, ar there any other things that need to be modified in order for the install. It's going on a b16a2 by the way.
Old Nov 5, 2004 | 02:52 PM
Two_K Si's Avatar
Default Re: What lines need to be tee'd off? AEBS typhoon install. (Two_K Si)
No one has installed a AEBS manifold on a 2000 Si??
Old Nov 14, 2004 | 09:11 AM
8krdline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Two_K Si &raquo;</TD></TR><TR><TD CLASS="quote">No one has installed a AEBS manifold on a 2000 Si?? </TD></TR></TABLE>
im about to so i'd like to know also
Old Nov 14, 2004 | 12:54 PM
Two_K Si's Avatar
Default Re: What lines need to be tee'd off? AEBS typhoon install. (8krdline)
Well, i installed it. Nothing needs to be tee'd off, im guessing what i had read was when the manifold first came out and was missing the nipple for the evap canister. But, you will need to plug a couple nipples on the back with caps. Also, there are 2 coolant nipples on the manifold, but i just caped one off and all is good. Finally, there is the mounting place on the runner for the IAT sensor, but Si's have them on the intake arm, so you will have to fa something up to cover it. If you need any help, ask
Old Nov 14, 2004 | 12:58 PM
PupaScoopa's Avatar
I installed one on my Si as well. I think I did have to tee off a vacuum line because I use cruise control. You can assemble it without the CC lines and just add a tee later.
My solution to the IAT sensor mounting was a pice of hose with a machine-threaded screw turned into it. The screw will expand the hose so it won't fall it or come out. I wish I could find a nice (diamond shaped/rounded edge) plate or something to cover that spot...
Old Nov 14, 2004 | 01:08 PM
eda6's Avatar
Default Re: What lines need to be tee'd off? AEBS typhoon install. (PupaScoopa)
My intake for a 92-95 civic has only one port on the intake (goes to valve cover). I used that. Ebay
Powered by VTEC
Jan 26, 2008 09:03 PM
egzo04
Jun 8, 2007 09:21 PM
cmsrally
10
Sep 25, 2005 03:22 PM
Two_K Si
Nov 3, 2004 06:35 PM
B18C-RnVA
Nov 17, 2002 03:22 PM
