obd2 to obd1 question???
i have a obd1 gsr motor that i am going to swap into my obd2 ek. i am going to use a obd2 si harness and i know that i need obd2 injectors,distributor,and alternator. can i use my stock d series injectors on my gsr? Thanx.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydm ferio »</TD></TR><TR><TD CLASS="quote">i have a obd1 gsr motor that i am going to swap into my obd2 ek. i am going to use a obd2 si harness and i know that i need obd2 injectors,distributor,and alternator. can i use my stock d series injectors on my gsr? Thanx.</TD></TR></TABLE>
You can run the OBD1 gsr injectors, distributor and alternator if you want. You will have to change the plugs out but easier then buying all new OBD2 stuff.
