engine building parts selection...
Old Apr 10, 2005 | 10:44 PM
quickersol's Avatar
Default engine building parts selection...
i'm working on getting things together for building up an ls-vtec and had a few questions in order to make sure i'm buying the right parts and not buying anything i do not need. i've built a few 4g63's already but this is my first honda and the open sleeve design and other areas have me curious.
for an engine capable of 500whp is a sleeved block necessary? what are opinions on acomplishing this with a block guard, block posting or filling the block?
is a cometic or similar style head gasket needed at this level? what about arp head studs? is it necessary to o-ring the block?
does anything need to be done to the griddle on the ls block for reinforcement?
is a replacement or performance water pump, timing belt, or oil pump necessary or recomended at these levels?
i belive i saw aftermarket knock sensor kits avalible for this motor. would this be recomended at a certian hp level? i feel alot safer tuning my motor knowing this but is it comonly used on high hp hondas?
i've done some searching on this for the last few days but can't find a solid answer to these questions. thanks in advance for all replys!
Old Apr 10, 2005 | 11:05 PM
PrettyLude's Avatar
anything past 450whp i would definately sleeve it, block guard is pretty much not needed when using aftermarket sleeves
oem head gasket will do the job, and take whatever you throw at it, arp studs are necessary to tie it down, o-ringing is just an option, i would prefer the step deck option
stock oem water pump, timing, and oil pump or you can go prodrive
kylea24
Jun 26, 2009 08:22 AM
civictyper99
Sep 14, 2004 08:34 AM
civictyper99
BaNAnABoAt689
Jun 13, 2004 07:53 AM
