Help, what's wrong with my TRUCK?
Old Apr 10, 2005 | 02:10 PM
EX-T's Avatar
Default Help, what's wrong with my TRUCK?
OK, I've got a '95 Mitsubishi Mighty Max with the 2.4L 4G64 engine.
The problem I'm having is my truck is that it's running extremely bad, like I've gotten water in my distributor cap because I did run through a HUGE puddle and it runs better on 3 cylinders than it does on 4 and it doesn't really matter which plug wire I pull off and there is no check engine light.
Everything I've done is...
-replaced the rotor button
-replaced the plugs
-replaced the plug wires
-replaced the distributor cap
-checked all vacuum hoses
-replaced the fuel filter
What should I check next? Timing?
Old Apr 10, 2005 | 02:18 PM
EX-T's Avatar
Default Re: Help, what's wrong with my TRUCK? (DSeriesBKilla)
bump...
darrinirox
11
Nov 10, 2012 05:07 PM
integ_lude
10
Oct 1, 2007 04:02 AM
ED8REX
Apr 25, 2006 09:25 PM
Jammersplace
17
Jan 29, 2006 04:11 PM
rasta420
Mar 8, 2003 07:17 AM
