HELP! Bogging/hesitation...possible misfire?
Old Apr 11, 2005 | 03:31 PM
brnyrdcmndo's Avatar
Default HELP! Bogging/hesitation...possible misfire?
I recently installed a 2000 ITR engine in a 98 EK hatch. Everything wired to OBD2A. Car boggs realy bad and even dies at times. Idles fine though. Replaced fuel pump, plugs, wires, cap & rotor. Fixed nothing! All sensors hooked up. Used a generic OBD2 scan tool......no codes! Have a fuel pressure gauge, what should fuel pressure be? Motor pro's please help!
Old Apr 11, 2005 | 09:15 PM
Default Re: HELP! Bogging/hesitation...possible misfire? (brnyrdcmndo)
Bump for the night crew!
Old Apr 12, 2005 | 05:40 AM
AM I in the wrong forum? Anybody?
Old Apr 12, 2005 | 10:45 AM
bump
Old Apr 12, 2005 | 10:51 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Did you make sure your MAP and TPS sensors are hooked to the right places? Is the timing correct? Maybe a plug wire or two in the wrong spot?
Old Apr 12, 2005 | 11:07 AM
Default Re: HELP! Bogging/hesitation...possible misfire? (JDM_Ej)
All wires are in the right spot. MAP & TPS sensors are hooked up to the right place (not switched). Checked timing and is correct. Just for the heck of it I pointed the timing light to the cam-gears while the engine is running and it looks like the intake cam is up one tooth (lines not directly parrellel to each other. I don't know if this means a whole lot because you aren't supposed to use timing light on cams only on the crank pulley, but thought I would share anyway, just in case.
Any other suggestions?
Old Apr 12, 2005 | 03:37 PM
Bump for the evening crew!
Old Apr 12, 2005 | 07:11 PM
red91sit's Avatar
Hmm well if if the cam is off by a tooth that could easily caust lots of problems with out shooting codes. I dunno how to check this ha ha, but if you do know how to, I'd check that first.
Old Apr 12, 2005 | 07:25 PM
mmuller's Avatar
Mad Scientist
check cam and ignition timing.
Old May 15, 2005 | 10:12 PM
jdm.ej's Avatar
Default Re: HELP! Bogging/hesitation...possible misfire? (mmuller)
i got the same exact prob how'd you fix it. i did everything you did to
eg grom
19
Jun 22, 2009 06:25 PM
mahatma
May 6, 2005 11:46 AM
brnyrdcmndo
Apr 12, 2005 03:37 PM
durrett syndrome
Sep 7, 2003 07:56 AM
boosted_zc
May 25, 2003 08:58 AM
