2001 prelude head gasket
i bought a lude from the guy with a blown head gasket. He claimed it was not over heated. Pulled off the head it was warped got it machined found war page on the block inner two cylinders. Should I risk putting head back on without machining the block?use any gasket sealer? I'm 2000 into it and might just sell if she runs and revs
It would start and run even if there was warp damage to the block, you would just get sealing issues. That being said, I believe it would have taken some pretty serious heating to warp the block with the head, as usually damage to the head happens first so you might be lucky enough to be good. Have you checked the block to see if it's straight? Pretty easy process
MigsD16
Engine Machining & Assembly
Dec 17, 2016 05:17 PM
Nick_Cartwright
Apr 4, 2013 08:55 AM
dominate9
Aug 26, 2003 03:17 AM
