gst misfire help!
Old Feb 14, 2015 | 02:05 PM
98gsrekhatch's Avatar
Default gst misfire help!
I have a gsr motor in my have I sprayed 100 shot direct port the other day it melted the plug on cylinder #1 replaced the plug and it's now not getting fire to the cylinder and the other 3 are when I pull the wire to see which one isn't firing it's # 1 but it not getting fire like the other three I replaced the wires I replaced the coil control module and cap and rotor still having the same problem any ideas?
Old Feb 15, 2015 | 12:52 PM
fcm's Avatar
fcm
Old Fart
Default Re: gst misfire help!
You have a GS-R engine in what?
You have a 100 shot what????
I will assume nitros, but what system, wet or dry?
To be of any help, I need MM&Y of car along with trim level and any mods.
You will need to be a lot more clear about what you have. 94
Old Feb 15, 2015 | 02:20 PM
HondaPartsHero's Avatar
Technical Hero
Compression test
Old Feb 15, 2015 | 03:37 PM
not sure what its in has to do with anything if you want a full build list I guess I can do that its a 98 civc hatch with 99 gsr engine cp 10-1 compression pistons eagle rods ry wire harness stock injectors stock fuel pump nos 100 shot wet direct port kit and also nx 75 shot wet kit (not in use atm) gsr trans everything else is new had everything check out before car was put together now on to the problem
not sure what a compression test has to do with not getting any spark to the wire when I pull the wire out you can here a good spark in 2-4 cylinders but #1 is very weak and sometimes not existent ive changed the cap rotor coil and ignitor plus and wires no change the plug gets soaked with fuel and sounds like a Subaru when you start it up going to try to get a new distributor tomorrow and see if that fixes it but I have my doubts not sure what else to look for and like I said ill restate it not sure what a compression test will do if im not getting spark to the end of the wire
Old Feb 17, 2015 | 12:42 PM
bump
Old Feb 18, 2015 | 01:31 AM
Technical Hero
Did you try another distributor?
Old Feb 18, 2015 | 03:36 AM
bent valve close thread plz
NosShootinHonda
Jan 20, 2009 04:45 PM
oneslowsohc
Feb 16, 2005 06:48 PM
IdotheSHOCKER
May 28, 2002 12:38 PM
94integrablur
Apr 26, 2002 05:43 AM
2fastGSR
Jun 26, 2001 09:10 PM
