rpm not working
Old Dec 16, 2014 | 06:05 PM
mateen123's Avatar
Default rpm not working
Hey guys I got 99 civic dx I did a b16a swap but now my rpm don't work. I bought an sir cluster and checked if if that was on, which it works. Also my distributor is a 10 pin and my harness is an si harness so that is 8 pin. I made my own conversion harness from 10 pin to I pin. And the blue wire I hooked up manually to the end it's spouse to go. Still does not work. Please and thank you
Old Dec 18, 2014 | 11:54 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: rpm not working
https://honda-tech.com/honda-civic-d...-help-2797011/
Old Dec 18, 2014 | 11:59 AM
larios2281's Avatar
did you convert your ecu to obd1?
Old Dec 25, 2014 | 02:41 PM
mateen123's Avatar
No I man using p2t ecu and yes that one wire I wired it up where it should go but it still does not work
jimlaH
K Series
Jul 23, 2012 11:10 PM
turbo_civicd16
May 12, 2009 10:28 AM
accordv66speed
Apr 24, 2008 04:41 AM
Akira-R
Apr 27, 2002 12:36 AM
