idle problem
Old Jan 2, 2015 | 06:35 PM
titan12's Avatar
Default idle problem
I have idle problem This is mi car https://m.youtube.com/watch?v=p2Gzhy7E288
AT 1997 Honda prelude took time looking for this failure and unresolved . I Change map sensor, change IACV (Idle Air Control Valve), clean the throttle and FITV (Fast Idle Thermo Valve), clean the egr, tps and is calibrated and i try whit another tps, ignition,new cable and new spare, fuel regulator, the car pulls no code. What else I can do? Q someone know?
Old Jan 3, 2015 | 08:17 AM
09chaplak's Avatar
Loves Tossing Salad
Default Re: idle problem
Have you done an idle relearn? The screw on the throttle body might need to be reset. What were the readings when you calibrated the TPS?
Old Jan 3, 2015 | 08:47 AM
titan12's Avatar
How do i make the idle relearn?
Old Jan 3, 2015 | 10:50 AM
09chaplak's Avatar
Loves Tossing Salad
https://honda-tech.com/honda-prelude...hread-1979500/
Old Jan 3, 2015 | 03:34 PM
holmesnmanny's Avatar
If your car doesnt die when it gets below 500 on the tach then it must just be the tach going bad. Check with an rpm enabled timing gun to be sure.
Jdm_Ej8_Sedan
Feb 26, 2014 09:13 AM
protopro88
Apr 8, 2011 03:41 PM
90AcuraIntegra04
Dec 11, 2005 05:26 PM
BACKWOODSTEG
Sep 10, 2005 10:08 PM
CRX-SIR
Sep 20, 2004 06:00 PM
