bottom end assembly ballancing
Old Dec 13, 2014 | 12:14 PM
raverx3m's Avatar
Default bottom end assembly ballancing
when putting together the bottom end
where do you start measuring?
the crank rod journals are different diameter
the rod big ends are different bore.
the rods have variance in length and weight and so do the pistons.
how do you balance it all up?
say I have everything measured, crank,rod bore,rod length and weight
piston weight etc
do I put it together and measure the piston to deck height first and then adjust the weight of each piston/rod to be even after I find the equal deck height for all pistons?
I have all the measuring tools and planning to do it myself but not sure what the proper way to do it.
Old Dec 14, 2014 | 05:36 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: bottom end assembly ballancing
Yes, do what you said but be sure each combination weighs / balances the same. Most of the time people just match each assembly to be the same weight and go from there.
Old Dec 14, 2014 | 10:26 AM
raverx3m's Avatar
ok thanks
im assuming that forged pistons like Wesco would have much more consistent measurements than OEM itr rods
Old Dec 15, 2014 | 03:00 PM
DO IT ON ALL FOURS
Yes, every Wiseco set I have ever had have been IDENTICAL measurements. Performance parts usually hold stricter machining tolerances as that is part of what you are paying for in the first place - quality.
myjdmsucks
Engine Machining & Assembly
Oct 8, 2015 11:17 AM
Johnny_9
69
Mar 10, 2011 03:09 PM
hondaapi
Feb 15, 2006 12:44 AM
EnzoSpeed
Aug 9, 2005 03:17 AM
CRX Lee
Feb 9, 2004 08:39 AM
