Plastic intake manifold & backfire
Old Feb 14, 2015 | 11:48 AM
genuser's Avatar
Default Plastic intake manifold & backfire
I have a 2014 CR-V with a plastic intake manifold. My previous vehicle has an aluminum intake manifold. Intakes seem to have gone plastic many years ago on many makes and models. I have also been reading about intake backfire when the a/f mix is too lean, intake valve open when the cylinder is fired etc., I have visions of the plastic intake manifold blowing up in my face when I am checking something in the engine bay while the motor is running
How does a plastic intake manifold hold up in the event of an intake backfire?
Old Feb 14, 2015 | 08:31 PM
bgdriver's Avatar
Default Re: Plastic intake manifold & backfire
You are more likely to die on an airplane piloted by Harry Potter with a winning powerball ticket in your pocket than you are to be in any sort of harm from the plastic intake. Unless you are spraying it with a ridiculous amount of nitrous while standing over the motor on a dyno pull or trying to diagnose a no start with starting fluid.
Old Feb 14, 2015 | 10:57 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
The intake comes apart,sometimes it splits in half,other times a big hole is blown. I ve seen a few become damaged due to back firing over the years.(Never on a Honda though,always Fords, and GMs)
Old Feb 15, 2015 | 05:52 AM
genuser's Avatar
So, are you saying these plastic intake manifolds can contain the backfire without getting damaged?
Old Feb 15, 2015 | 05:55 AM
genuser's Avatar
Did Honda do anything in the design (electrical or mechanical) to prevent intake backfire from ever occurring? (like some kind of an interlock between the ignition and cam systems)
Old Feb 16, 2015 | 10:58 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
No. Ford and GM have been using plastic intakes for a few decades. Im sure once Honda gets there,they'll have a few blown manifolds.....
Old Feb 16, 2015 | 10:59 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
For quite some time,yes. Eventually they will give way if subjected to enough stress....
Old Feb 16, 2015 | 06:03 PM
bgdriver's Avatar
No, but your odds of encountering a random intake backfire on a perfectly running engine while you are directly on top of it are fantastically astronomical.
LawlessOne
Sep 15, 2007 05:40 PM
