Broken VTec pressure switch
Old Feb 21, 2015 | 09:49 AM
SiRCiviC94's Avatar
Default Broken VTec pressure switch
Got a block where the pressure switch broke off and was bj welded shut. Now what?
It's a usdm b18c1 Gsr engine
I may have to scrap the block I am a little curious what affect this would have? VTec will still engage? If it doesn't leak is this very risky?
I got this in a trade and just noticed the jb beside the oil filter for the pressure switch
Old Feb 21, 2015 | 10:33 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Broken VTec pressure switch
Bypass it
VTEC Oil Pressure Switch Wiring Bypass
Old Feb 21, 2015 | 11:40 AM
SiRCiviC94's Avatar
Sure bypass the wiring. But how hack is this jb weld is it under pressure? % chance it's going to ruin the engine at some point?
I'm really iffy. Also from a sale stand point is it for parts or can it be used?
Old Feb 21, 2015 | 11:43 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Vtec pressure switch is on the cylinder head next to the distributor, not on the back of the block next to the oil filter. I believe you are referring to the oil pressure sending unit for the instrument cluster idiot light. A single yellow/red stripe wire connects to it. If this is missing or unplugged, you will not get a red warning light on the instrument cluster when the engine oil pressure drops below 7psi.
Old Feb 21, 2015 | 01:56 PM
SiRCiviC94's Avatar
My mistake yes the oil pressure sensor.
It's jb welded I am super skeptical of that
Old Feb 21, 2015 | 03:53 PM
SiRCiviC94's Avatar
Looks like I'll sell it as running since no leaks. Sucks tho
Old Feb 22, 2015 | 12:09 PM
94EG8's Avatar
Seagull Management
Why don't you just knock the JB Weld out with a pick and then remove the broken piece with an easy out? It shouldn't come out hard at all. Then simply replace the sending unit.
Old Feb 23, 2015 | 06:10 AM
SiRCiviC94's Avatar
Can't say for sure, it it's probably ripped out already and no thread left. Once the jb is off the block case has to be machined and cleaned lol
I'm happier with how it is at this time since it doesn't leak and it'll be me using it.
I don't want to sell something that's no good but seems it's not as drastic as I thought. Fresh rebuild Gsr block... Add 12psi 57trim turbo. 12.3-12.5 car all day? ;p
Old Feb 23, 2015 | 08:02 AM
spAdam's Avatar
Loved
Community Favorite
I've repaired ones that are cracked by from over torquing the sensor. Just a little weld & blend, then re-tap the hole. No big deal, especially if the motor is out of the car.
barone
25
Aug 20, 2009 08:32 AM
FlyingDaggers
Nov 9, 2007 11:48 AM
white90rexsi
Jul 3, 2007 10:08 AM
bruthaboost
Sep 28, 2002 04:32 PM
