99-00 keyless into 93 si
Old Dec 15, 2014 | 05:31 AM
HDSlo...GUY's Avatar
Default 99-00 keyless into 93 si
I am currently building my 93 si and have decided to add a few features. I have the key fob and the module from a 99 sedan. Currently, I am working on the wiring situation and need any advice that is out there. I have already converted my si to the coupe power options.
Old Dec 15, 2014 | 07:18 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Default Re: 99-00 keyless into 93 si
The optional keyless entry/security system wiring harness piece would be very helpful in your case.
Old Dec 15, 2014 | 09:02 AM
spAdam's Avatar
Loved
Community Favorite
Post up the wiring diagram for the keyless module from the 99 and the door lock system from the 93 from the Helm manuals. If it's doable that will be your key.
Honestly, you might as well just look in to installing an aftermarket alarm. It's a modified 93 Civic, so it needs a security system anyway.
Old Dec 15, 2014 | 09:12 AM
deschlong's Avatar
Loved
Community Favorite
^ This. Clifford or Viper system will provide better security anyway, and just as much hassle to install if you're going to DIY it. Stealth install is best.
Old Dec 18, 2014 | 09:29 AM
I have a diagram for both and it does look as if it would work. The major thing would be relocating the module of the eg from the door to the new module of the ek to inside the car. I won't be needing a security system as of now I am now going crazy with the vehicle just adding some minor touches.
Old Dec 18, 2014 | 09:54 AM
deschlong's Avatar
Loved
Community Favorite
If you're set on this, I'd suggest a 97-01 CRV keyless entry unit or 98-01 Integra keyless entry (which was optional). These have setups based in the door, more like the EG units. The CRV retrofit has been completed successfully by another user (angrysmileyface).
Old Dec 22, 2014 | 09:28 AM
Thanks you I will check that out! Hopefully I can find one or the other lol.
Old Dec 23, 2014 | 09:52 AM
thedudeabides's Avatar
Where did you pull the module from in the sedan? I am having a hard time finding mine, both in the car and online....
Old Dec 29, 2014 | 03:45 AM
The module is located in the driver side kick panel. I know that 99-00 ex sedans have it.
thequesogrande
May 13, 2013 11:34 AM
carl1864
Dec 12, 2011 08:15 AM
Nocturnal
Sep 10, 2005 11:34 AM
jdmfbpsi
Audio / Security / Video
Jun 14, 2005 08:36 AM
Simple SOHC
Dec 17, 2003 10:46 AM
