96 civic random bogging
Old Feb 15, 2015 | 04:47 PM
GingerJ20's Avatar
Default 96 civic random bogging
I have a stock 96 civic auto as my daily driver for the last fee months it has developed a reason bogging concern. When cruising bellow 3000 rpm it will start to bog like it's running outa fuel. If u boot it it clears up and all Is fine. Fuel pressure is good new filter plugs cap rotor wires new. It's so random it will be fine for days the then come back. Just wondering if anyone else has experienced this. Gonna check o2s and map Tomorow
Brian
Old Feb 15, 2015 | 05:26 PM
GingerJ20's Avatar
Default Re: 96 civic random bogging
So Frusterating to diag because it's so random
Old Feb 16, 2015 | 03:16 PM
GingerJ20's Avatar
Almost a 100 km round trip today to work and back didn't do it once. I forgot to mention no codes
GingerJ20's Avatar
I'm leaning towards random map issue
Old Feb 16, 2015 | 10:25 PM
holmesnmanny's Avatar
It wont be the map sensor unless it throws a code. Check for any and all stored codes first.
Old Feb 17, 2015 | 07:50 AM
GingerJ20's Avatar
There are no codes I heck it everyday this isn't my first rodeo
Old Feb 17, 2015 | 01:31 PM
Replace the upstream oxygen sensor with a Denso.
Old Feb 17, 2015 | 02:52 PM
GingerJ20's Avatar
Common problem ?
Old Feb 17, 2015 | 07:26 PM
The oxygen sensor only is used at idle up to light throttle. Its possible your oxygen sensor is fouled.
Not saying its going to fix your issues but its definitely possible.
I would check for an exhaust leak using seafoam anywhere from the exhaust manifold to the oxygen sensor first.
Old Feb 17, 2015 | 07:53 PM
GingerJ20's Avatar
No leaks Thanks for the tips
Old Feb 23, 2015 | 01:03 PM
Jowrx05's Avatar
had a similar issue a few months ago, was barely noticeable and got worse over a couple months. Had to replace an intake valve with a nice chunk burned out of it. Compression test and then go from there. I found out really quick due to zero compression in cylinder 3. Good luck!
Old Feb 23, 2015 | 05:25 PM
GingerJ20's Avatar
Thanks but a burt intake valve would create a noticeable miss. This is not like that completely random
Old Feb 27, 2015 | 12:07 PM
hondacivic97si's Avatar
10 Year Member
Had the same problem. But now it also stalls. The car is practically worthless.
My suspicions: Faulty ignition switch wiring, or fuel delivery issue. (pump/filter/injectors) etc.
Let me know if you solve this!
Old Feb 28, 2015 | 09:06 AM
09chaplak's Avatar
Loves Tossing Salad
Tighten/clean G101, ground on thermostat housing.
Old Mar 2, 2015 | 07:57 AM
GingerJ20's Avatar
I replaced the map sensor on sat with one from the wrecker has been good ever since I will update in a few days. I commute almost 100 k a day so if it's not fixed it will happen soon. But is very Frusterating as it is so random
Old Mar 2, 2015 | 10:41 AM
GFamilyProject's Avatar
i worked on a civic with same issue. it had egr though cleaned out all ports and ran fine after that
Old Mar 2, 2015 | 05:38 PM
GingerJ20's Avatar
96 ex auto doesn't have egr does it ?
Old Mar 3, 2015 | 09:13 AM
GingerJ20's Avatar
Map sensor has seemed to fix the issue fyi
Old Mar 7, 2015 | 08:56 AM
GingerJ20's Avatar
Been running great all week
Shoulda gone with my gut from the get go and replace the map
Oh well go a good used one from the wreaker for 10 bucks
Ahmed Hussein
Sep 7, 2017 09:30 AM
ShadowWalker-Ek
12
May 24, 2012 04:42 PM
S2k Hybrid
Apr 28, 2007 03:40 PM
ICEDOWT
Nov 17, 2003 10:15 PM
