B18c O2 sensor plug came off of engine harness!!
Old Jan 27, 2015 | 07:53 PM
EF'GSRrr91's Avatar
Default B18c O2 sensor plug came off of engine harness!!
The engine harness I'm using is unknown, I have a b18c swapped into an EF. The O2 sensor is a 4 wire sensor, white, green and two blacks. The four wires coming out of the harness are purple, grey, tan, and I think pink.. Anyways, I tested the four harness wires and got the hot 12v wire identified... Leaving three wires. I'm not sure which one is the signal wire and which two are the grounds... and I also don't know which points go in the plug and can't find a diagram. Please help.
Old Jan 27, 2015 | 09:28 PM
2point1's Avatar
Default Re: B18c O2 sensor plug came off of engine harness!!
Can you Post pics of the ecu plugs? I can tell you what wire is what by looking at the ecu plugs and will tell you where in the O2 plug they go.
Old Jan 28, 2015 | 07:52 AM
EF'GSRrr91's Avatar
Get under the dash and pull the plug and take a pic? If I get the hot wire to where it needs to go, I believe I can just mix and match the other three till it's right?
Old Jan 28, 2015 | 08:48 AM
EF'GSRrr91's Avatar
Old Jan 28, 2015 | 08:54 AM
EF'GSRrr91's Avatar
The female plug looks to say dpfi z6/D15
Old Jan 28, 2015 | 09:06 AM
EF'GSRrr91's Avatar
Old Jan 28, 2015 | 09:12 AM
EF'GSRrr91's Avatar
Top of connector (backside)
|(1)(2)|
|(3)(4)|
1. Signal
2. Ground
3. 12v switch (hot)
4. Heater/ecu
Does this seem right???
Old Jan 28, 2015 | 10:15 AM
EF'GSRrr91's Avatar
Crappy pic but these are the harness wires for the O2 sensor.. Yellow(12v), purple, pinkish orange, and a thicker insulated white wire.<br/><br/>
Old Jan 28, 2015 | 12:31 PM
2point1's Avatar
Using the pic below. This is looking at the back side of the O2 plug where the wires go in.
Top left=signal d14 at obd1 ecu plug
Top right= sensor ground d22 at obd1 ecu plug
Bottom left =power
Bottom right=heater ground a6 at obd1 ecu plug.
This is the female plug that goes on the engine harness. I can't tell from the pics you post where the wires are going to tell you what wire is what. You can trace the wires from the obd1 ecu plugs to see what color wire does what and then put it in the plug where it needs to go.
Here's a pic of the obd1 ecu plugs showing where the numbers are to make it a little easier for you.
EF'GSRrr91
Jan 22, 2015 01:23 PM
miasma
Jan 12, 2007 12:34 AM
hondaboy90
Oct 1, 2006 06:03 PM
Ransom
Feb 16, 2006 04:10 PM
NatedoggAZ
Nov 8, 2003 03:59 PM
