Crazy Idle
Old Jan 16, 2015 | 09:51 AM
weaslehunter1's Avatar
Default Crazy Idle
What up all. Having the typical up and down idle issue usually associated with the IAC valve. Went to a junkyard and pulled three off of other civics and tried them all with the issue still remaining. Thinking next check should be a vacuum line check, any recommendations?
Old Jan 16, 2015 | 10:01 AM
holmesnmanny's Avatar
Fitv needs to be tightened down or you have a vacuum leak.
Old Jan 16, 2015 | 10:24 AM
Default Re: Crazy Idle
Does it need to be adjusted just for a high or a low idle, or for that and a loping idle? It idles real high when the IAC is connected and lopes when I disconnect it and its been running a while. its pretty inconsistent too, some days are better than others.
Any better ideas to check for vacuum leaks other than soapy water?
Old Jan 16, 2015 | 04:17 PM
Just tighten the plastic down til its barely snug.
And use carb or throttle cleaner if the problem doesnt go away.
Old Jan 26, 2015 | 03:49 PM
masospaghetti's Avatar
The crazy up-and-down is from the FITV leaking. Tightening it down seems to help some people, but if you take out the cylinder completely by unscrewing it, you'll see there's a rubber o-ring on the thing that is undoubtedly rock hard and not doing its job.
I took the o-ring to NAPA and they were able to match up one for 99 cents. The regular black o-rings or the green refrigerant o-rings both work.
sc440
Jul 27, 2010 08:22 PM
GSTDA9
Feb 7, 2008 03:59 PM
UNKNOWN_MEMBER
Aug 11, 2005 08:55 PM
rice a roni
Apr 15, 2005 09:49 AM
4gen
Jan 11, 2004 05:28 PM
