wiring help
Old Mar 1, 2015 | 03:35 AM
Daonlyone74's Avatar
Default wiring help
OK guys I have a 99 b16 motor in an 96 ek coupe. This car is a full race car will never be on a street only the track. Question is I have the 96 ex engine wire harness and an obd1 ecu with jumper harness. I don't have any other wires in the car ( no gauge cluster or dash harness or floor harness) I want to run the motor with a switch panel. 1 for ignition a push button start and 1 for fuel pump and other 1 for radiator fans.. I know I need relays for the switches but how do I wire them all into the car.
Old Mar 15, 2015 | 05:15 AM
Default Re: wiring help
Anyone got any ideas ?
Old Mar 15, 2015 | 07:26 AM
2point1's Avatar
Run power to the relays #30
Run trigger wire from switch to relay #86
Ground #85 on relays
#87 is power out to fuel pump,starter,Ecu.
There's 3 wires on the engine harness that tie together yellow/black and two black/yellow wires.
The switches will all so need a power to one side.
This all depends on what type of relays and switch panel you use. This is the most common way of wiring it.
Old Mar 15, 2015 | 08:02 AM
OK yeah I know how to do the relays they are basic 5 pin 12v 30/40 a relays...just using toggle switches for the fuel pump and radiator fans and ignition...battery will be on a shut off switch and starter will use a push button. Just didn't know how what needed to be hooked to engine harness for it to run or if just plug in it into the ecu is fine...like the end of the harness the would plug into the chassis harness by driver door. Do I need to connect anything to that ?
Old Apr 13, 2015 | 07:12 PM
Bump
Old Apr 14, 2015 | 08:48 AM
2point1's Avatar
The 10 wires plug on the drivers side from the engine harness has all the wires you need to get the motor to run.
Big black/yellow wire
Small black/yellow wire. All 3 of these wires tie together
Small yellow,black wire
The big black/white is the trigger for starter.
Old Apr 26, 2015 | 07:24 PM
What three wire do i tie togeether. So just twist them together and solder them to become on big wire...then when I flip switch for ignition it will send 12v to all 3 wires?
Old Apr 28, 2015 | 07:56 AM
2point1's Avatar
You tie the two black/yellow wires and yellow/black wire together making them one.
Old Apr 28, 2015 | 09:35 AM
So then that's all the will go to my ignition switch
Old Apr 28, 2015 | 03:54 PM
2point1's Avatar
Yes sir. Make sure the ignition switch is fused.
Old May 17, 2015 | 09:33 AM
What size fuse should I run for the ignition, fuel, and fans ?
honda_lx
May 20, 2014 10:45 AM
wutupnut
May 17, 2011 04:11 PM
plaidjppatches
Jan 13, 2011 12:29 PM
H23_del_soul
Aug 26, 2010 04:30 PM
RTW DC2R
Dec 31, 2004 04:58 PM
