B18c5 engine ignition trouble
Old Dec 24, 2014 | 12:07 PM
Smccorkeljr's Avatar
Default B18c5 engine ignition trouble
Hi first off,I'm a complete noob when it comes to Hondas.I have a 2000 civic with a b18c5 swap.I bought the car with the swap already done.Recently my car has started to "stumble" at highway speeds.I have changed the plugs,wire,fuel filter to no avail.I went and bought a new distributor cap and rotor,but the ignition rotor that is on my car does not have the screw in the side of it to remove the rotor.Is there any way to remove the ignition rotor,and when I do get it removed where can I find a replacement?Plus when I bought the distributor cap, the cap for the b18 did not fit,I had to buy the cap for the b16,so I'm guessing the distributor is for a b16?I am completely lost and any help will be greatly appreciated.
Old Dec 30, 2014 | 11:53 PM
hondawhiz's Avatar
Default Re: B18c5 engine ignition trouble
You have a integra type r distributor. The rotor should pull right off. Does your engine consume coolant?
Old Jan 2, 2015 | 04:08 PM
09chaplak's Avatar
Loves Tossing Salad
What distributor did you get? Check to see if your mechanical timing is correct.
adzhiametov
Feb 10, 2015 08:55 AM
William1991b
Oct 9, 2011 07:44 PM
wesk18
Sep 30, 2009 04:14 PM
dlric
Dec 13, 2001 03:55 AM
