Crank sensor
Old Feb 7, 2015 | 11:51 AM
Thategguy94's Avatar
Default Crank sensor
My friend recently bought a blown up b20 swapped crx and had a running totaled crv we swaped the motors at knock sensors where the same but the crank sensor on the new motor didn't have a plug on the harness for it so this car won't run it starts on a bump start but don't know what to do about that crank sensor and if it's our problem any ideas
Old Feb 7, 2015 | 01:15 PM
2point1's Avatar
Default Re: Crank sensor
If your using an obd1 ecu you don't need the crank sensor. If using an obd2 ecu there's a bypass you can do. The motor should start and run with the crank sensor disconnect. So your problem cloud be something else.
nels00n
19
Aug 16, 2010 08:04 AM
jjmcmana
Nov 1, 2008 09:02 AM
FOMULA91
Nov 17, 2005 10:33 PM
