dead cylinder HELP!!!!
Old Feb 18, 2015 | 07:03 AM
d16gt2871r's Avatar
Default dead cylinder HELP!!!!
so i bought a turbo 99 civic, d16z6. it has a huge list of aftermarket parts on it including a brand new head with new valves retainers ETC... would it have a dead cylinder because the valves need adjusting? or would it be something else. if so can someone give me an idea to what it might be. hoping i dont need rings.
Old Feb 19, 2015 | 04:49 PM
hybridmiklo's Avatar
Default Re: dead cylinder HELP!!!!
Did you do anything to figure it out? did you do a compression test ? did you check with a noid light that every injector is energizing? Did you check for spark on everything cylinder? Did you do anything?
Old Feb 22, 2015 | 01:28 PM
09chaplak's Avatar
Loves Tossing Salad
To answer your question, no. A valve lash on the loose side of things will not cause a cylinder to loose compression. What symptoms are you getting that make you think one of your cylinders isn't holding compression?
Old Feb 22, 2015 | 01:59 PM
JDMH22HATCH's Avatar
If you have valves way too tight then yes you can have a cylinder with low compression.
Start simple. Check for spark. Check for fuel in that cylinder. Do a compression test. Check valve clearance. Then go from there.
Old Feb 23, 2015 | 12:00 PM
d16gt2871r's Avatar
It has spark, when you pull the spark plug wires or one by one the idle drops until you get to cylinder 4.
Old Feb 25, 2015 | 01:15 PM
Swap the wire with a different cylinder and see if the misfire follows it. If it does then the wire is bad. If cylinder 4 still is misfiring then look into adjusting the valves, check the contact point on the rotor for cyl 4 and go from there
Team_Coast978
Aug 24, 2013 09:31 PM
Team_Coast978
Engine Management and Tuning
Jun 10, 2013 10:58 AM
dmonk87
Dec 3, 2011 05:27 AM
egjack
Dec 2, 2010 06:43 AM
2000siturboR
Sep 20, 2007 02:00 PM
