HELP!!!
Old Feb 18, 2008 | 06:28 PM
juniestyle's Avatar
Default HELP!!!
Ok...i checked my clutch master cylinder and there was no fluid...well obviously cuz my pedal was to the ground...i couldnt find the leak at first...so i changed out everything...the master cylinder, the slave cylinder, and the lines that go to the master cylinder to the slave cylinder...but still after couple days pedal to the floor and no fluid...where else would it be leaking from???
Old Feb 18, 2008 | 07:26 PM
all-mtr-teg's Avatar
Default Re: HELP!!! (juniestyle)
If everything has already been changed, and your sure everything was tightened properly, the only other place is the metal line itself. Do you see a puddle of clutch fluid in the morning after being parked overnight?
Old Feb 19, 2008 | 03:43 PM
juniestyle's Avatar
Default Re: HELP!!! (all-mtr-teg)
no i couldnt find any leaks...anyone else can help me out???
Born2Build
May 22, 2011 06:02 PM
jdmfeing
Mar 8, 2011 07:45 AM
juniestyle
Jan 25, 2008 02:31 PM
94accord718
Oct 5, 2007 01:28 PM
