compression test FAQ clear up
Old Feb 19, 2008 | 11:19 AM
polishedturd's Avatar
I like PIE
Default compression test FAQ clear up
So after reading some horror stories about what people have done to their motors while performing a compression test i would like for someone to clear a few things up.
#1-should i have all of the spark plugs out while performing the test or just one at a time?
#2-i should pull the ecu fuse out so that fuel is not shot into the cylinders, correct?
#3-should i disconnect the dizzy so that i dont blow the coil?
#4-should i lube the threads on the tester so that it wont get stuck?
its seems like a pretty simple procedure and im not understanding why so many people are having problems. thanks for your help in advance
Old Feb 19, 2008 | 12:22 PM
ddd4114's Avatar
Default Re: compression test FAQ clear up (polishedturd)
Pull the ECU fuse. It will protect the coil and prevent fuel from being injected. It doesn't matter how many plugs you pull since you're only testing one cylinder at a time. Anti-seize may help if you won't want the tester to get stuck.
Make sure the test is performed with a warm engine and wide open throttle.
Old Feb 20, 2008 | 03:22 AM
I like PIE
Default Re: compression test FAQ clear up (ddd4114)
thanks
gs-R_swap
Oct 4, 2009 12:12 PM
xJDMCx
May 29, 2009 06:10 PM
B18CivicHatch
Aug 24, 2007 12:11 AM
DRKSol
Jan 18, 2006 08:23 AM
Traction
Apr 6, 2004 06:11 PM
