GSR bogging after vtec??
Old Feb 14, 2008 | 12:29 PM
91EF_Si's Avatar
Default GSR bogging after vtec??
So I bought a 91 hatch with a 94 obd1 gsr swap. The guy I bought is from saids after he put in the Eldebrock Victor X manifold, it's been bogging at high rpm's. So yea, thats basically the problem..low end power is ALL there but 5k + it bogs BAD and vtec sometimes works and shuts down. I got a CEL code 22 for vtec oil pressure switch. I changed the vtec selonoid and tried other ecu's and it still does the same shyt. Should I just take his word and put the stock manifold and see what happens??
Old Feb 14, 2008 | 02:40 PM
King V's Avatar
Default Re: GSR bogging after vtec?? (91EF_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">I got a CEL code 22 for vtec oil pressure switch. I changed the vtec selonoid.....</TD></TR></TABLE>
The pressure switch tells the solenoid there is enough oil pressure to allow the VTEC system to activate. Change/swap/diagnose the vtec oil pressure switch and then see what happens. The ECU probably thinks there isn't enough pressure, hence VTEC not activating.
Old Feb 14, 2008 | 03:22 PM
91EF_Si's Avatar
Default Re: GSR bogging after vtec?? (King V)
how can i diagnose the switch?
btw: it always bogs when it hits vtec, then around 8k it just takes off and u hear vtec LOUD.
Old Feb 14, 2008 | 06:18 PM
91EF_Si's Avatar
bump
Old Feb 14, 2008 | 07:02 PM
91EF_Si's Avatar
found a vid online...it does somethin like this..
Old Feb 14, 2008 | 08:20 PM
4dooritr's Avatar
check your timing
Old Feb 15, 2008 | 09:18 AM
HOODLOVER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dooritr &raquo;</TD></TR><TR><TD CLASS="quote">check your timing</TD></TR></TABLE>
huh?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King V &raquo;</TD></TR><TR><TD CLASS="quote">
The pressure switch tells the solenoid there is enough oil pressure to allow the VTEC system to activate. Change/swap/diagnose the vtec oil pressure switch and then see what happens. The ECU probably thinks there isn't enough pressure, hence VTEC not activating.</TD></TR></TABLE>
what he said^^^
Old Feb 19, 2008 | 09:11 AM
King V's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">how can i diagnose the switch?</TD></TR></TABLE>
I don't have the manual handy, but if its a 2 pin switch, it should have power on one pin, and the other pin should go to the ECM, telling the computer the switch is either open or closed. You could try jumping the terminals(if there are 2) to fool the ECM into thinking the switch is closed, and see what happens.
mike_h22a1/cd5
Oct 20, 2013 02:15 AM
cioli
12
Feb 26, 2006 08:31 AM
jdmsiR20
35
Apr 3, 2005 01:32 AM
allnapower
Apr 1, 2005 08:22 AM
singlecamcrx
Nov 24, 2004 02:10 AM
