Floor jack
Old Feb 23, 2008 | 07:26 AM
NuRon's Avatar
Default Floor jack
I'm in the market for another one, as my Crapsman crapped out on me from a leaking seal. Are there any suggestions for a broke college student? Husky, Schucks, Vatozone, etc. are where I'm looking at. I know they're simple parts stores but I've read of people getting a part-store-China-special and having it last a long time with a bag of replacement seals and everything . No balling business please , 2 tons minimum, thanks .
Old Feb 23, 2008 | 07:27 AM
Kiwibird83's Avatar
Reigning GDD Queen
Default Re: Floor jack (NuRon)
Harbor Freight, I've used my jack from them for years and cost me barely a dime.
Old Feb 23, 2008 | 08:40 AM
cd5_2NR's Avatar
Default Re: Floor jack (Kiwibird83)
i thought crapsman had lifetime warranty on their products..???
or is that for tools only
Old Feb 23, 2008 | 09:00 AM
TOAB's Avatar
Default Re: Floor jack (cd5_2NR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cd5_2NR &raquo;</TD></TR><TR><TD CLASS="quote">i thought crapsman had lifetime warranty on their products..???
or is that for tools only</TD></TR></TABLE>Hand tools only.
Old Feb 23, 2008 | 09:08 AM
gospeedgo1's Avatar
Default Re: Floor jack (TOAB)
costco sells one. a low profile all aluminum jack if i remember correctly and you know you can always return it if it goes bad. 89.99
http://www.costco.com/Browse/P...en-US
Old Feb 23, 2008 | 09:14 AM
B96v6's Avatar
Default Re: Floor jack (gospeedgo1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gospeedgo1 &raquo;</TD></TR><TR><TD CLASS="quote">costco sells one. a low profile all aluminum jack if i remember correctly and you know you can always return it if it goes bad. 89.99
DO NOT buy this jack! We bought 2 for work and there are tons of better choices out there. The hydraulic piston is weak and it has a very low lift height - about 3" lower than any others out there. I bought a Torin steel unit from Pep Boys for about $100. It has a low deck height (great for lowered cars) and raises up to about 18". It's steel, so its heavy as hell, but it's in my home garage, so I don't have to move it too often.
B
Old Feb 23, 2008 | 09:37 AM
graveltravel2's Avatar
i bought some cheap and crappy "race jack" from walmarks for less than 50 bucks.
by "race jack" i meant one that is made for lowered cars. ive used it over 10 times and it still works fine.
Old Feb 23, 2008 | 10:50 AM
Sketch_hs's Avatar
i got a jack from kragen like 6 years ago, the heavy duty one... was like 150. I've used it probably a thousand times... never had any issues!
Old Feb 23, 2008 | 11:18 AM
__oversea's Avatar
Default Re: (Sketch_hs)
this might thin your wallet but, i believe its the best out there.
ac hydraulic
Old Feb 23, 2008 | 11:26 AM
homey dont play dat's Avatar
Default Re: (Seungho.K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seungho.K &raquo;</TD></TR><TR><TD CLASS="quote">this might thin your wallet but, i believe its the best out there.
ac hydraulic </TD></TR></TABLE>
ive got this beast: http://www.drivewerks.com/cata...1.htm
honestly my garage is a little tight for it though and its kinda a pain to move around and **** though. other then that its and awesome jack.
ive heard norco makes good floor jacks as well.
Old Feb 23, 2008 | 11:29 AM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: (homey dont play dat)
I know exactly which craftsman jack the op has. I'm willing to bet it's the same one I have and every single person that buys this piece of **** jack gets fuked over when it stops working. What an ungodly piece of ****. I hope this jack burns in hell.
boosteda9's Avatar
any reviews on the general-(brand) low profile at harbor freight? going for around 180-200?
Old Feb 23, 2008 | 11:31 AM
ILcrxsi1's Avatar
Default Re: (boosteda9)
Am I right OP or am I right?
http://www.sears.com/shc/s/p_1...pment
Don't any of you guys ever ever ever ever buy this piece of ****.
Old Feb 23, 2008 | 12:22 PM
the weasel's Avatar
Default Re: (ILcrxsi1)
My previous floor jack was a 2 1/2 (I think) ton Harbor Freight. It leaked after about 4 months of occasional use.
I wouldn't recommend it to anyone but it seems that the leaky seals seem to be common regardless of brand. My Craftsman seems to be doing OK after a year of occasional use *knocks on wood*. It's just the regular 3 ton jack, not the one ILcrxsi1 linked.
Old Feb 23, 2008 | 12:56 PM
Tizight's Avatar
I bought a cheap jack from walmart for $45 and its been working fine for 3 years now.
Old Feb 23, 2008 | 02:20 PM
gospeedgo1's Avatar
Default Re: (Tizight)
napa carries one also.
Old Feb 23, 2008 | 02:37 PM
iam7head's Avatar
Default Re: (gospeedgo1)
why not just replace the seals?
are you even sure you need the seal? most of the time it just air in the system.
when my crapsman took a dump i just change the oil and bleed the air, it works like new now(3 years, used all the tiem)
Old Feb 24, 2008 | 11:17 AM
NuRon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">I know exactly which craftsman jack the op has. I'm willing to bet it's the same one I have and every single person that buys this piece of **** jack gets fuked over when it stops working. What an ungodly piece of ****. I hope this jack burns in hell.</TD></TR></TABLE>
Yeah, it seems to plague the whole range of models from the cheap to the high-priced. I've been using my emergency jack that came with the car to raise one side then put a jackstand on it and repeat the steps on the other side, as it's a lot less headache than using the Crapsman doorstopper .
I wante to try the one from NAPA but there seems to be no warranty on it while Schucks does have a one year thing with their product.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kiwibird83 &raquo;</TD></TR><TR><TD CLASS="quote">Harbor Freight, I've used my jack from them for years and cost me barely a dime.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the weasel &raquo;</TD></TR><TR><TD CLASS="quote">My previous floor jack was a 2 1/2 (I think) ton Harbor Freight. It leaked after about 4 months of occasional use.
I wouldn't recommend it to anyone but it seems that the leaky seals seem to be common regardless of brand. My Craftsman seems to be doing OK after a year of occasional use *knocks on wood*. It's just the regular 3 ton jack, not the one ILcrxsi1 linked.</TD></TR></TABLE>
Contradicting reviews like this makes me wary of getting a jack since I was about to head to Harbor Freight this week! I appreciate it very much though because they're helping with my decisions. I think I might look at Walmart or Schucks later on.
iam7head, the seal kit runs for about $50 and Sears sometimes does not carry it. As for how I know, underneath the lever, I noticed oil seeping out everytime I give it a pump so I'm thinking the seals are gone.
Old Feb 24, 2008 | 11:57 AM
screwballz's Avatar
Default Re: (NuRon)
i have a crappy jack that i bought from discount auto parts. not sure on the brand but it was under $100 i remember that. it was yellow. i've had it for about 6 years now. no problems yet. seems like its getting a little weak but still gets the job done.
Old Feb 24, 2008 | 12:05 PM
gospeedgo1's Avatar
Default Re: (screwballz)
my uncle has a harbor frieght jack, probably about 5 years old now. no real problems with it.
Old Feb 24, 2008 | 01:11 PM
NuRon's Avatar
http://www.harborfreight.com/c...94629
http://www.harborfreight.com/c...34271
http://www.harborfreight.com/c...91039
Any thoughts? Last one is a bit expensive for me.
Old Feb 24, 2008 | 01:14 PM
FifthGearOnline's Avatar
Default Re: (NuRon)
either one of the first 2 you have listed.
Old Feb 24, 2008 | 01:36 PM
gospeedgo1's Avatar
Default Re: (FifthGearOnline)
my uncle has the orange one. the last one looks pretty nice, does harbor frieght include a warranty with their products?
Old Feb 24, 2008 | 02:50 PM
Bjorn20's Avatar
Default Re: (NuRon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NuRon &raquo;</TD></TR><TR><TD CLASS="quote">http://www.harborfreight.com/c...94629
pretty sure i got the top one a few months ago, used it a few times with no problems other than its a little slow. But its also cheap and harbor freight.
Old Feb 24, 2008 | 03:29 PM
NuRon's Avatar
The second link has a 90-day warranty. What do you guys say?
