Battery Relocation Wire Gauge
Old Feb 19, 2008 | 04:54 PM
AntMan401's Avatar
Default Battery Relocation Wire Gauge
Is 0 Gauge absolutely necessary or could I use 4 or 6 Gauge? Also, should I put in an inline Fuse before the Battery or no? If so, what kind of fuse? One of the Inline Fuses thats used when installing A Sound System (Subwoofers) or something else.
Thank You
Ant
Old Feb 19, 2008 | 05:10 PM
ctr83's Avatar
Default Re: Battery Relocation Wire Gauge (AntMan401)
0 or 2 gauge 4 and 6 is too small and know need for fuses.
Old Feb 19, 2008 | 09:50 PM
slowcivic2k's Avatar
0 gauge would be recommended. DO NOT FUSE OFF THE POSITIVE BATTERY POLE. The starter draws over 200A and will blow any fuse you throw in there. All your doing is moving the battery, so all you need is wire for the relocation. Attempt to keep the battery negative ground in the engine bay. This will allow starter current to find its way back to the battery easier.
Mike Hoffman
Mar 31, 2013 11:07 AM
JuneBugDrfter
Feb 26, 2013 11:49 AM
dylaxiin
May 11, 2011 07:11 PM
tunes12
Jul 28, 2003 05:07 PM
KooK
Jul 21, 2003 02:49 PM
