Hondata S300 installed in P28 throwing code 23--Knock Sensor
Old Feb 17, 2008 | 04:01 PM
C_Rock77's Avatar
Default Hondata S300 installed in P28 throwing code 23--Knock Sensor
I picked up an S300 unit from a friend. It's installed in a P28. I was running my car (Stock GSR--Intake, header, exhaust) on just your old plain run of the mill OBD1 P72. I have a car I plan to put this S300 on, but was trying to run it on the relatively stock car (which doesn't throw any CELs on the OBD1 P72) to make sure everything was ok.
Well, the unit is throwing code 23 for the Knock Sensor when I run it on the S300. When I run it on the regular P72...no CEL. Any suggestions, guys?
Specs:
S300 installed in P28 running stock JDM P72 map.
Car: 99 GSR I/H/E. I'm using a jumper harness that I was using with the OBD1 P72.
I drove it yesterday on the P72...no CEL. Drove it today on the S300, throws Code 23. Reinstalled the P72...no CEL.
What do you guys think?
Old Feb 17, 2008 | 10:51 PM
C_Rock77's Avatar
Default Re: Hondata S300 installed in P28 throwing code 23--Knock Sensor (C_Rock77)
All these views and NO replies? C'mon guys, I need some help, here!
Old Feb 17, 2008 | 11:00 PM
phearable's Avatar
The p28 ecu has no knock sensor cirq. Go into your paremeters in the s300 software & disable the knock sensor.
Old Feb 17, 2008 | 11:46 PM
C_Rock77's Avatar
Default Re: Hondata S300 installed in P28 throwing code 23--Knock Sensor (phearable)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phearable &raquo;</TD></TR><TR><TD CLASS="quote">The p28 ecu has no knock sensor cirq. Go into your paremeters in the s300 software & disable the knock sensor. </TD></TR></TABLE>
Thanks John. I was looking and looking for that option and couldn't find it. Looked in Settings, Sensors, etc. Thanks for letting me know it's in PARAMETERS.
Is that why the system is throwing that code? B/c the P28 doesn't have knock?
LUDEcidDream
Engine Management and Tuning
Jul 19, 2010 02:01 PM
Stingray96
Oct 31, 2005 09:38 PM
CR_VtecCRX89
15
May 19, 2005 07:17 PM
kholmes
Mar 11, 2005 08:30 PM
matman4444
Jul 30, 2004 09:30 AM
