Brake issue
Old Feb 16, 2008 | 06:15 PM
Vanadium's Avatar
Default Brake issue
I changed my front pads and had no problems,
took car for a drive with no issues.
I then changed my rear pads,
when I took the car for a drive I noticed that the hand brake light was on,
-it wont turn off regardless of the handbrake position.
-the hand brake itsnt really working that well.
Thanks Jade
Old Feb 17, 2008 | 07:25 PM
CAM0FLAG3's Avatar
Default Re: Brake issue (Vanadium)
Im guessin your rear set up is a pad/ drum. If so what you need to do is take off the rotos in the rear and you'll see for the drum set up.. Between the two shoes there is a rod that has a starwheel adjuster. turn it a couple clicks to retract the rod. Put the rotor on. THEN go and check the e brake. If this is very confusing to you i suggest going to pep boys kragen or autozone and buy a repair manual for like 20 bucks....
Vanadium
Mar 7, 2008 03:26 AM
miksew
Oct 7, 2006 11:46 PM
Extremity
Apr 8, 2006 04:59 PM
Tyson
20
Jan 14, 2004 10:54 AM
fred92htch
Oct 10, 2002 07:18 AM
