Probelm with Engine.. really need inputs
Old Feb 17, 2008 | 11:54 PM
JerkDC2's Avatar
Modified by JerkDC2 at 2:54 PM 3/4/2008
Old Feb 18, 2008 | 12:26 PM
97grnrs's Avatar
Default Re: Probelm with Engine.. really need inputs (JerkDC2)
what color is the smoke? if its a shop that did the work they should have had the head pressure checked and shaved down . if not then u gonna have to do it all again prob. block is hard to warp. head can warp from overheating. of improper torque and stuff.. head could even have a crack. or he did something wrong and didnt clean the surfaces good enough ... look towards the head getting pressure checked and decked
Old Feb 18, 2008 | 04:13 PM
lanzo88's Avatar
if he removed the head improperly that could cause it to warp. you have to remove each head bolt in a certain sequence and remove each one 1/4 turn at a time. this may be a long shot but are you sure h replaced the head gasket. same thing happened to a friend of mine and the mechanic tried using the old head gasket. make sure your coolant lines are routed correctly as well. make sure you dont have lines routed straight into the intake.
Old Feb 18, 2008 | 07:32 PM
JerkDC2's Avatar
Default Re: Probelm with Engine.. really need inputs (lanzo88)
thx for good info guys anything else.. any one else wanna chime in
Old Feb 18, 2008 | 09:23 PM
JerkDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">what color is the smoke? </TD></TR></TABLE>
It was WHITE
Old Mar 1, 2008 | 01:01 PM
Kyoh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lanzo88 &raquo;</TD></TR><TR><TD CLASS="quote">if he removed the head improperly that could cause it to warp. you have to remove each head bolt in a certain sequence and remove each one 1/4 turn at a time. </TD></TR></TABLE>
Are you sure about that 1/4 turn a time? I'm pretty sure that you just need to loosen them in sequence but not a quarter turn at a time?
new_climber
12
Jan 13, 2009 09:08 AM
teggyracer91
Mar 26, 2007 12:06 PM
I8ayellowcrayon
18
Jan 29, 2004 11:42 AM
blwnb16a
Dec 18, 2003 02:59 PM
fiftee_su
Oct 8, 2003 09:23 PM
