want to install a girdle on the b20
Old Feb 18, 2008 | 08:04 PM
psi4boost's Avatar
Default want to install a girdle on the b20
i will try to make this as simple as possible.
im doing a b20 vtec turbo built.
i have a balanced crank that uses 0.25 main and rod bearings and i want to put it into the b20 block also along with a gsr girdle. What do i have to do? as in making it work without any problems
Old Feb 19, 2008 | 12:29 PM
psi4boost's Avatar
Default Re: want to install a girdle on the b20 (psi4boost)
anybody
Old Feb 19, 2008 | 12:39 PM
96Spec Ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psi4boost &raquo;</TD></TR><TR><TD CLASS="quote">i will try to make this as simple as possible.
i have a balanced crank that uses 0.25 main and rod bearings and i want to put it into the b20 block also along with a gsr girdle. What do i have to do? as in making it work without any problems</TD></TR></TABLE>
You will need to pick up a gsr girdle and 2,3, and 4 main caps or just get a z10 girdle for 160. You will need to get gsr main studs or oem bolts then have the main bores align honed at a reputable machine shop. You will also need a gsr windage tray, pick up tube and oil pan.
Old Feb 19, 2008 | 02:04 PM
Golden Eagle's Avatar
i have a balanced crank that uses 0.25 main and rod bearings and i want to put it into the b20 block also along with a gsr girdle. What do i have to do? as in making it work without any problems</TD></TR></TABLE> if you put a gsr girdle on a b20 you will also need 2 3 and 4 mains gsr mains bolts/studs windge tray oil pick up and oil pan and it will have to be line bored or you can buy our dowled main girdle we sell it in a kit with all you need less the oil pan or just by it self. when you buy a aftermarket girdle be sure that it is made to be dowled to the mains or you might as well not put one. pm me if you have anymore questions
Old Feb 19, 2008 | 11:10 PM
psi4boost's Avatar
Default Re: want to install a girdle on the b20 (Golden Eagle)
i have everything for it already, i have the whole gsr girdle with the main caps.....
im i suppose to use the b20 main caps?
Old Feb 20, 2008 | 04:18 AM
mmuller's Avatar
Mad Scientist
gsr main cap
Old Feb 20, 2008 | 07:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psi4boost &raquo;</TD></TR><TR><TD CLASS="quote">i have everything for it already, i have the whole gsr girdle with the main caps.....
im i suppose to use the b20 main caps?</TD></TR></TABLE> if you are going to do that be sure to line bore not line hone the block. if you want the truth i would not wast your money unless your building some full race 800hp motor because we have made over 800hp with no main girdle many times with no problems
Old Feb 20, 2008 | 06:30 PM
psi4boost's Avatar
thanks, i guess no girdle........but still doing that +500hp
TurbodTegSfaria
Oct 5, 2009 03:36 PM
krazeenoy
Mar 30, 2008 04:38 PM
civicswap
Mar 19, 2006 05:27 PM
H23vtecEG
10
Jan 22, 2005 02:34 PM
mitsuman
Oct 21, 2004 03:43 AM
