timing light question
Old Feb 17, 2008 | 03:42 PM
royalfelix's Avatar
Default timing light question
ok so i have a 92 honda prelude si, and want to set the timing right. i have looked on youtube and seen how they hook up the trigger gun and it flashes but how is it that you know where to set the disb.
Old Feb 17, 2008 | 08:51 PM
inspyral's Avatar
The crank pulley is marked at TDC(white), stock timing(red), and +/- 2 degrees(brown marks on either side of the red mark). If your timing light is non-adjustable, then you rotate the distributer until the red mark on the crank pulley lines up with the pointer on your lower timing cover. There are also adjustable timing lights that I have little experience with, but you usually dial in your desired timing and then the light will compensate for that setting and you'd line the white TDC mark up with the mark on your lower timing cover. I believe some of the digital timing lights will also give you a direct reading on the light itself.
Old Jan 25, 2009 | 09:38 PM
HTautodc's Avatar
Default Re: timing light question
i'm reviving the thread since i don't want to make people mad if i create a new thread :D
if i move the dizzy while adjusting, wouldn't i get electrocuted? i'm paranoid
Old Jan 25, 2009 | 09:42 PM
Scott_Tucker's Avatar
Hold onto the cap or the body of the distributor but not onto the wires and you should be fine. It won't kill you or make you sterile if you get shocked although it is not pleasant.
Old Jan 25, 2009 | 09:49 PM
Radim's Avatar
or wear gloves resistant to shock.
Old Jan 25, 2009 | 10:52 PM
HTautodc's Avatar
hold on to the cap or body? is this the metal thing or the black plastic? any of you guys got electrocuted before? :D
Old Jan 26, 2009 | 06:00 AM
fcm's Avatar
fcm
Old Fart
LOL, lots of times, no biggie, it is unlikely you will get a shock even if you hang on the the spark plug leads themselves, unless you have a bad spark plug or an unplugged spark plug lead.
As mentioned a shock from a spark plug lead is not going to do much more then make you jump and swear, high voltage/low amperage, and it's amps that kill
Yes a shock from your cars ign. system is not pleasant, but it is nothing to worry about. 94
Old Jan 26, 2009 | 03:30 PM
a1320addict's Avatar
If youre that worried about it, you can tap it with a rubber mallet or something similar.
Volts are for thrills, amperage kills.
A shock from the stock ignition isn't that bad, MSD Digital with a HVC coil knocked me on my *** though, lol
Old Jan 26, 2009 | 08:08 PM
HTautodc's Avatar
*lol* ok. i'm counting on your words, pals *lol*
honda4fun
Jun 11, 2009 04:09 PM
civic_driver
May 7, 2009 03:46 PM
NSfit
10
Nov 14, 2006 11:17 AM
slowd16z6
Mar 13, 2004 02:20 PM
david90
Nov 18, 2003 10:09 AM
