what would no knock sensor do?
Old Feb 24, 2008 | 02:33 PM
cehcivic15's Avatar
Default what would no knock sensor do?
what would happen if i unplugged my knock sensor on my b16a, would it cause it to idle funny and die when i pressed on the gas?
Old Feb 24, 2008 | 04:05 PM
inspyral's Avatar
It'll throw the knock sensor code, unless you disable it with an aftermarket EMS.
Old Feb 24, 2008 | 04:10 PM
zccr-xsi's Avatar
Default Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">It'll throw the knock sensor code, unless you disable it with an aftermarket EMS.</TD></TR></TABLE>
or through a chipped ecu!
Old Feb 24, 2008 | 07:53 PM
cehcivic15's Avatar
Default Re: what would no knock sensor do? (cehcivic15)
well, i just dropped a jdm b16a into my 95 civic dx and it starts....idles badly...and dies when i press the gas...have no idea what it could be
Old Feb 25, 2008 | 04:13 AM
zccr-xsi's Avatar
any codes?
Old Feb 25, 2008 | 04:25 AM
cehcivic15's Avatar
Default Re: (zccr-xsi)
it is throwing a cel, i jumped it to see what it was, and the srs blinked instead of the cel, it read, 21, 21, 11, 21, 11, 21, 21, 11, 21, 11
doesnt make sense to me
Old Feb 25, 2008 | 12:17 PM
EGJason's Avatar
The 95 DX isn't wired for VTEC. It needs the VTEC, VTEC oil pressure, and knock sensor wiring hooked up. You'll have to wire these up to fix it.
Old Feb 25, 2008 | 07:03 PM
cehcivic15's Avatar
Default Re: what would no knock sensor do? (EGJason)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGJason &raquo;</TD></TR><TR><TD CLASS="quote">The 95 DX isn't wired for VTEC. It needs the VTEC, VTEC oil pressure, and knock sensor wiring hooked up. You'll have to wire these up to fix it.</TD></TR></TABLE>
i know this.....but vtec has nothing to do with why my car is idling funny and dies when i press the gas, it wont even rev past 1500 before dieing
b18cEF9
Dec 20, 2004 04:22 PM
1SickHb
Nov 19, 2004 04:39 PM
birds_sol_94
Aug 19, 2004 04:23 PM
smslude
Jan 14, 2003 10:37 PM
clean99teg
Sep 21, 2002 05:43 PM
