CHECK ENGINE LIGHT
Old Feb 16, 2008 | 12:47 PM
chirpinfourth's Avatar
Default CHECK ENGINE LIGHT
Car: 1995 Integra LS coupe
Motor: JDM b16a2
Trans: stock LS (i know)
Not sure how much help I can get on here with this issue but its worth a try. My check engine light just came on. Here is what I have done today:
1. Put a bracket on the radio. (could I have messed up some wiring? all audio equip still works fine but would there be some sort of delayed problem? The light cam on hours after I did this so I dont think it's related)
2. Got a car wash. (could water have gotten somewhere it wasnt supposed to and cause the light to come on? ( the light came on less than a minute after the wash and there was a "Rocker panel/ undercarriage blaster" involved in this high-dollar Sheets endevour. not sure if this could be the problem but sounds reasonable.)
3. I have 3 bad motor mounts currently according to my local dealership. Im not sure how this could trigger the CEL besides too much movement of the motor which could lead to something being disconnected/disturbed)
My inspection dies this month and this is my DD so all help is very much appreciated.
Thanks
Old Feb 16, 2008 | 12:58 PM
HRTuning's Avatar
Default Re: CHECK ENGINE LIGHT (chirpinfourth)
It could have been caused by water getting where it shouldn't be. Why not just check the code and find out what the problem is?
Old Feb 16, 2008 | 01:42 PM
Default Re: CHECK ENGINE LIGHT (HRTuning)
How do you check the code? I need some sort of diagnostic comp. for that, correct?
Old Feb 16, 2008 | 02:12 PM
... just kidding. The man upstairs has a twisted sense of humor because the CEL is off now so I wont need to be checking that code... for now. I guess it was the water that caused the problem and I suppose it dried??? Sorry for the false alarm. Oh and I figured out how to check the CEL.
Admin delete?
hondagall10
Aug 21, 2010 07:08 PM
marinersfaninmd
Acura TSX
Jun 15, 2009 07:24 PM
soloteg2
Jun 14, 2006 05:44 PM
pens81
Acura TSX
Mar 30, 2006 03:42 AM
Preludegirl
Dec 3, 2003 08:14 AM
