oil pressure question
Old Feb 24, 2008 | 10:41 PM
obuhmyuh's Avatar
Default oil pressure question
i know you can bypass your oil pressure sensor by tapping ur oil pressure sensor wire into your vtec solenoid wire. could this possibly solve a code 21 (vtec spool solenoid) if it is indeed my oil pressure sensor causing this code?
Old Feb 26, 2008 | 12:30 AM
slowcivic2k's Avatar
Default Re: oil pressure question (d[sick]sTeena)
The VTEC spool solenoid is the solenoid that actuates VTEC, there is a small spool valve inside the VTEC solenoid body. If you have this code, there are three possible causes:
1: Solenoid is blown, and is not accepting commands from the ECU.
2: The Spool valve is jammed in the body due to oil coking/debris, use brake cleaner or another solvent to clean it out. This can cause condition 1.
3: You have a wiring problem between the solenoid, and the ecu.
A bad VTEC oil pressure switch will cause VTEC to not activate, but it will throw a completely different code. (Code 22)
Old Feb 26, 2008 | 10:07 AM
obuhmyuh's Avatar
Default Re: oil pressure question (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">The VTEC spool solenoid is the solenoid that actuates VTEC, there is a small spool valve inside the VTEC solenoid body. If you have this code, there are three possible causes:
A bad VTEC oil pressure switch will cause VTEC to not activate, but it will throw a completely different code. (Code 22)</TD></TR></TABLE>
well i replaced the spool solenoid and im still getting it, so i guess i gotta look at my wiring
singlecamcrx
Nov 24, 2004 02:10 AM
danteisme
Sep 26, 2004 03:19 PM
Driven
Sep 20, 2004 08:45 PM
BobGnarly
May 23, 2004 05:28 PM
1ntensiveVTECivic
Nov 17, 2003 12:51 PM
