Clutches and Transmissions
Old Feb 20, 2008 | 12:08 PM
Seminole's Avatar
Default Clutches and Transmissions
Ok, so I don't remember so I'm asking. I have a hydro transmission and I'm looking at picking up a cheap clutch that was barley used on a cable transmission. So my question would be would that clutch that was used on a cable transmission work on a hydro transmission? Help asap would be much appricated.
Thanks
Old Feb 20, 2008 | 01:29 PM
Seminole's Avatar
bump. Need to know like tonight perferably. My block is in machine shop waiting to be balanced (needs flywheel and pressure plate)
Old Feb 20, 2008 | 01:34 PM
ctr83's Avatar
Default Re: (Seminole)
i know b-series are.
Old Feb 20, 2008 | 01:47 PM
Seminole's Avatar
It's B series. I got the anwser though. I'd need a new disk, release bearing and alignment tool. Someone correct me if I am wrong?
Old Feb 20, 2008 | 02:33 PM
inspyral's Avatar
Cable and hydro B series clutches are different, although flywheels are interchangable. As such, either cable or hydro pressure plates will bolt up, but I'm unsure if a hydro disc will work with a cable pressure plate and vice versa. If you need to get a new disc, pilot bearing, throwout bearing, and allignment tool, why not just get anwhole new clutch kit?
Old Feb 20, 2008 | 09:15 PM
Seminole's Avatar
Default Re: (inspyral)
Hmmm, I was told by ACT that it would work as long as I got a new disk, release bearing and alignment tool (which is like $200 total). The reason why is because I got screw over on my taxes and I need a clutch before I can drive my car. I was going to get a brad new Tilton full assembly.
Old Feb 21, 2008 | 11:35 AM
ctr83's Avatar
i used the same clutche in cable and hydro tranny. it was ls but thir all the same.
Old Feb 21, 2008 | 05:41 PM
Seminole's Avatar
Default Re: (ctr83)
It depends on the year of the transmissions apparently.
Old Feb 22, 2008 | 08:32 AM
ctr83's Avatar
my tranny was 95.
fatpride111
Oct 26, 2010 01:36 PM
db owner88
Mar 17, 2009 11:16 AM
Beau Gotti
Feb 27, 2006 09:40 PM
g2_teg_
Dec 15, 2005 06:46 PM
