rebuild kit for 95 gsr
I have a 95 gsr I need to rebuild and I had found this kit on ebay that comes with civic type r pistons is says that with using b8c1 it would give me 12.04:1 cr at this site http://cgi.ebay.com/ebaymotors...06874
please check it out and tell me what you thank
I here it is not safe to run those pistons in a b18c1 because the compression would be to high for pump gas is this true should I not thank about it?
with compression that high you will get a ping and you will have to retard the timing / get a tune
i would recommend bigger cams/ a .040 cometic head gasket to lower the compression
. WAAS_SAPPENING
15
Jun 12, 2006 06:51 PM
panykus
15
Sep 19, 2004 08:55 PM
Ragezero76
May 15, 2002 04:33 PM
Halo
May 2, 2002 01:11 PM
