Replacing H22 rings question
Old Feb 19, 2008 | 02:54 AM
djnikko's Avatar
Default Replacing H22 rings question
Im about to change the rings on a h22a engine, is there anything else I need to check or do whilst I have the engine apart? (This is the first time Ive had to change rings) Do bearing clearances need to be checked? any honing? plasti gauge-ing?
Any tips would be appreciated
Old Feb 19, 2008 | 11:44 AM
98vtec's Avatar
moderator emeritus
Default Re: Replacing H22 rings question (djnikko)
would strongly recommend a rehone.
Old Feb 19, 2008 | 02:03 PM
djnikko's Avatar
Default Re: Replacing H22 rings question (98vtec)
Do I need different sized piston rings if im honing? Or you mean just a minimal amount to give the new rings a slightly newer surface to bed into.
Old Feb 21, 2008 | 12:42 PM
djnikko's Avatar
bump for some info
Old Feb 22, 2008 | 11:22 PM
deucedeuceEK's Avatar
remember, you have frm sleeves
Old Feb 27, 2008 | 06:39 AM
djnikko's Avatar
Default Re: Replacing H22 rings question (deucedeuceEK)
I thought their might be something a little different with H22 sleeves, does this mean rings are have to be oversized slightly? Or just no honing is required? Id like to know the difference, I believe these are on the F20c also.
cheers
Old Feb 27, 2008 | 06:52 AM
98vtec's Avatar
moderator emeritus
depends on the exact size of the bore as it stands now. Honing takes very little material from the cylinder bore so as long as you dont go over the service limit of the standard bore, you will be fine with standard sized rings.
Old Feb 27, 2008 | 07:41 AM
djnikko's Avatar
Cheers, I have the workshop manual and measuring tools so I guess i'll strip it down and measure before ordering rings. How do the sleeves being FRM affect the changing of the rings?
Old Feb 27, 2008 | 07:50 AM
98vtec's Avatar
moderator emeritus
you have darton sleeves which are iron, not FRM.
the process of changing the rings is no different than any other motor. the difference lies in the honing process which requires a different crosshatch degree and a different stone.
Old Feb 28, 2008 | 12:52 AM
djnikko's Avatar
Sorry for the confusion I just realised in my sig it says darton and thats for my H22 CRX. The EG civic I own is having a stock H22 put in, so I guess that means they are FRM? If they are FRM from stock.
Cheers
Old Feb 28, 2008 | 04:38 PM
H24A96EK's Avatar
if it's not sleeved then yes you have the frm sleeves from honda. they require a 600grit hone at 45-55 rpm and i forget off hand what the angle for the crosshatching is. it may be 60 i think, and cleaning often between. really strict instructions i know and the main reason it is so hard to have this done is there isn't may shops that have a honing maching that will go so slow. i think if you can simply find a shop that can do the lower rpm required then you should be set. they may not stock 600grit for they're machine as i would imagine that isn't called for often. something else you could do is to install liners (thin sleeves) which i was quoted at 400 for install and final bore here at a local shop. an easy overbore of the sleeves to make room for the "sleeves". they are thinner and don't require an insane amount of work and you can then run any stock ranged size piston either oem, or forged without any problems. not needed but an overlooked "upgrade for a decently built engine.
Old Feb 29, 2008 | 07:54 AM
djnikko's Avatar
Default Re: (H24A96EK)
I see, thanks for the reply So I am unable to do this in my home garage? I have a honing tool with I believe attaches to a drill, maybe a pillar drill. I have another H22 which has had alot of machine work so im trying to do this block on the cheap
Cheers
leng_p_xiong
Sep 15, 2008 07:30 PM
sadam-insane
Jun 9, 2008 07:22 AM
Silvertc
Mar 10, 2008 08:35 AM
Aaron.Hillman
Acura NSX
Jul 19, 2006 03:47 PM
