please help asap
Old Feb 23, 2008 | 08:00 PM
michaelrichardobrien's Avatar
Default please help asap
I am not to familiar with transmissions and i discovered this "issue" tonight when i jacked my car up look look for an oil leak which i think ended up being from my oil pan gasket. anyway i looked over at the trans and saw that there looked to be a missing cover on the drivers side. looks like if it were ther would almost overlap or butt up next to the oilpan. the ironic thing is. I thought my throw out bearing was bad could it be my trans not having that cover?
Old Feb 24, 2008 | 04:03 PM
inspyral's Avatar
If you're referring to the flywheel cover that covers the gap between the block and tranny, it shouldn't have any effect on leaking fluids. A bad throwout bearing wouldn't cause any fluid leaks either, so your oilpan gasket assessment is probably right. I would try and source the flywheel cover anyway, just to prevet foreign objects from getting in there.
Old Feb 24, 2008 | 07:27 PM
yeah I asked someone about it today and that was what it was. thanks for the help though. i appreciate it
Vague
Jun 2, 2015 05:42 AM
hedge6504
May 31, 2014 09:01 PM
Crxmick
13
May 27, 2012 07:11 PM
gsxr1k05
Sep 25, 2006 05:18 AM
crzyfool24
18
Jun 6, 2005 07:54 PM
