Wastegate install help
Old Feb 18, 2008 | 02:20 PM
Poey2's Avatar
Default Wastegate install help
The instructions say to connect the top of the wastegate (Tial) to a vacuum source before the throttle body plate. I dont have any ports to connect to before the throttle body. Can I use the vacuum source after the throttle body? The ones from the IM? What is the difference?
I know the blow off valve goes to the IM vacuum source.
Thanks in advance.
Paul
Old Feb 18, 2008 | 06:46 PM
NJIN BUILDR's Avatar
Default Re: Wastegate install help (Poey2)
Top port is for boost controller.Side port is for vacuum source.Many people use a t in the brake booster line.
Old Feb 18, 2008 | 10:55 PM
inspyral's Avatar
As stated above, you should be connecting the side port to a boost source, and the top port isn't used unless you have a boost controller. While you can technically use any boost source, including an intake manifold source, for the side port of the wastegate, TiAL recommends it be a boost-only source, before the TB. The reasoning behind this is that with a boost-only source, the diaphram inside the wastegate essentially undergoes less stress. If the diaphram sees vacuum, it gets stretched in one direction, then when it sees boost, it gets stretched in the other direction. This can lead to premature wastegate failure. However, it should be noted that many people(myself included) have used a manifold source for wastegate reference with no ill effects.
Old Feb 19, 2008 | 05:27 AM
Poey2's Avatar
Default Re: (inspyral)
Thank you for clarify that for me. That was the answer I was looking for.
Old Feb 19, 2008 | 05:30 AM
Poey2's Avatar
Another question for you.
If I disconnect the wastegate, my car will not see any boost? I want to drive the car without boost until it gets to a tuner.
Thanks
Paul
Old Feb 19, 2008 | 03:09 PM
inspyral's Avatar
Yes, if you take the wastegate off, you won't see boost since you'd be pumping exhaust out of the wastegate port.
turbo sol
Mar 1, 2009 08:47 AM
evilhatch2.0
Jan 31, 2005 07:11 AM
Hoosier Daddy
May 19, 2004 07:36 AM
filetofit
Jun 10, 2002 03:26 PM
