Dist no spark
Old Feb 21, 2008 | 07:32 PM
civicstar's Avatar
Default Dist no spark
i got a GSR OBD1 that i rewired and soldered to an OBD2 plug. everything color matched. when i got it it didnt have an internal coil so i took one off a running 96 sohc CX. got new cap and new wires and rotors and when i went to go fire, it gets no spark, what other internal part could need to be changed?
I tested another GSR dist and it starts the car up.
Modified by civicstar at 9:31 PM 2/21/2008
Old Feb 21, 2008 | 09:44 PM
98vtec's Avatar
moderator emeritus
Default Re: Dist no spark (civicstar)
its possible the coil you installed was bad to begin with.
Old Feb 22, 2008 | 11:34 PM
civicstar's Avatar
Default Re: Dist no spark (98vtec)
the coil i had was off a running CX, the coil was from the old motor i used to run
Old Feb 23, 2008 | 05:33 AM
GhostAccord's Avatar
Could be the igniter, try using the one from the good dist and see if that works.
Old Feb 23, 2008 | 08:50 AM
civicstar's Avatar
Default Re: Dist no spark (GhostAccord)
i replaced it and i will try to start it up and test soon, thanks
egsicxxx
Feb 3, 2013 09:15 AM
joemommaaa
Feb 20, 2011 06:01 PM
JDM_EK4_Coupe
Apr 10, 2007 06:05 AM
civickiller
Feb 21, 2007 03:11 PM
Yambor
Jul 30, 2004 06:55 AM
