rev limiter kicks on at 2500 after swap HELP!!!!!
Old Jun 13, 2008 | 12:49 PM
firefighter8013's Avatar
Default rev limiter kicks on at 2500 after swap HELP!!!!!
i havea 96 honda accord ex vtec. i put a jdm engine in it and now the dam thing wont go over 2500. but the rev limiter kicks it down to idle if i let off the gas. if i dont let off the gas it dies and doesnt want to start (check engine lite flickers when this happes also.
Old Jun 13, 2008 | 01:09 PM
EG_Warped's Avatar
Default Re: rev limiter kicks on at 2500 after swap HELP!!!!! (firefighter8013)
are you running the JDM ECU?
Old Jun 13, 2008 | 06:02 PM
Default Re: rev limiter kicks on at 2500 after swap HELP!!!!! (EG_Warped)
no i switched everything over for the us stuff not to familiar with this stuff though
Old Jun 13, 2008 | 06:03 PM
no i switched everything over for the us stuff not to familiar with this stuff though is there a difference and if so how would i get the ecm
Old Jun 14, 2008 | 11:05 AM
EG_Warped's Avatar
what engine did you put in it?
Old Jun 14, 2008 | 04:13 PM
i put the f22b engine in. i switched over the oil pump that had the crank sensor
///Mo-betta
Jul 26, 2021 11:38 AM
2ndchirp
Feb 27, 2009 03:18 AM
95eg-K
Jan 22, 2008 03:02 PM
jdm4life
Oct 15, 2002 08:17 AM
