Clutch Kit Question
Old Jun 15, 2008 | 04:06 PM
matt2001teg's Avatar
Default Clutch Kit Question
I have a 2001 gsr. I am doing a ACT clutch kit and flywheel. I wanted to know if I have to do any adjustments on clutch pedal or can I just put everything back together the way that it came apart? Secondly this is my first time pulling my transmission is there any tips or things I should look out for? Thanks in advance
Old Jun 16, 2008 | 10:54 AM
vtecb18c's Avatar
Default Re: Clutch Kit Question (matt2001teg)
make sure you dont forget the throw out bearning,,,you dont need to make any adjustments usualy....just make sure you use the alignment tool they give you
Old Jun 16, 2008 | 01:51 PM
Default Re: Clutch Kit Question (vtecb18c)
I have that bearing and the pilot bearing also...hopefully I don't run into any problems
Old Jun 17, 2008 | 08:58 AM
vtecb18c's Avatar
well good luck...and make sure you clean the hell out of the flywheel before you put it in
Old Jun 17, 2008 | 11:14 AM
I got the trans out of the car last night...looks like my pressure plate failed. One of the springs broke and caused the disc inside the plate to shatter into three peices. Was pretty crazy never seen anything like that before.
Old Jun 17, 2008 | 11:56 AM
vtecb18c's Avatar
ouch...nothin else wrong with the tranny?
hillbillycivic
Aug 17, 2012 05:25 PM
h8ted ek
Dec 22, 2006 07:41 PM
poserbmx
Jul 10, 2006 05:17 PM
CardDealer
Jun 6, 2004 03:10 PM
SD_EM1
Jul 26, 2003 10:33 AM
