Trans leak
Old Jun 15, 2008 | 10:08 AM
Paul-eg's Avatar
Default Trans leak
Hey,
Ive got a b16 trans with a kazz lsd. Ive always got a drop of trans oil on the bolt on the casing bolt on the bottom of the trans that is closest to the rad support. I pulled all those bolts off and put RVT on them all and along the casing...still have the drop. What could this be and how could I stop it?
Thanks
Modified by Paul-eg at 10:43 PM 6/15/2008
Old Jun 16, 2008 | 05:11 AM
Paul-eg's Avatar
Default Re: Trans leak (Paul-eg)
ttt
Old Jun 16, 2008 | 09:29 PM
Paul-eg's Avatar
Any ideas what else i could try?
Old Jun 16, 2008 | 11:01 PM
inspyral's Avatar
Was the casing sealed properly when it was reassembled? It could be seeping through at the seam and just collecting on the lowest bolt. I would also check the fill/drain crush washers, since those will also seep some fluid if overtightened.
92 hatchback
Feb 16, 2009 02:00 PM
civicpark81
Feb 25, 2008 05:26 PM
_HANS
Oct 3, 2005 08:36 PM
.Ryan
Mar 20, 2005 11:47 AM
RCautoworks
Feb 16, 2003 11:16 PM
