head gasket question
i put a brand new head gasket on my b20 and torqued it down to correct specs, the motor was not turned on. the head was only torqued down for about 1 hour and i realized i needed to take the head back off. my question is do i need another new head gasket to finish or can i use the one i just had . i also am using copper spray gasket sealer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japanstar_ef9 »</TD></TR><TR><TD CLASS="quote">i put a brand new head gasket on my b20 and torqued it down to correct specs, the motor was not turned on. the head was only torqued down for about 1 hour and i realized i needed to take the head back off. my question is do i need another new head gasket to finish or can i use the one i just had . i also am using copper spray gasket sealer.</TD></TR></TABLE>no you should be fine as long as you didn't run a heat cycle threw it.
autowrench07
Jul 26, 2012 07:55 AM
